I think you guys have been involved emotionally and financially for a long time, I am new to this and I see a big picture. Not so emotionally attach. Just rational, pragmatic.
What I see is a guy on a mission. He will succeed.
At the Fremont event I sat in the rear and noticed when I exited the car my foot hit the rear door panel. I took a look at all the panels and noticed they all are 2-3 inches thicker than the door panels in the cars I drive. My takeaway from the event was the beta interior was not complete; I had hoped the extra thick door panels would slim down but that does not appear to be the case.
Here's photos of the Model S white beta and the prototype Model X front door panels. Clearly, Tesla can make a thinner door panel as evidenced by the Model X on display. Why is the Model S door panel so thick? It interferes with exiting and without storage pockets I don't see a need for them to be as thick as they are.
Yes, it probably seems like nit picking, is it to much to want something a bit more refined when the Model X looks like its there already?
The BMW picture brought something to my attention that I hadn't really noticed before. The Model S uses a "half door" (not sure what to call that), in that it doesn't have a full frame above the window. Most of the cars I've dealt with use full-framed doors. I suppose since the Model S door has one less seam up top (just the seam between window and body, and not window to frame, and frame to body as with a full-frame door), it could potentially be quieter. What do you think the pros and cons are between both door types?
The only time I've driven a car with frameless windows, it was more prone to air leaks due to unreliable sealing between the window and the roof. The window seemed to flex out of place when there was a pressure differential (gust of wind, passing truck), releasing pressure on the seal and causing leakage. Mind you that was some years ago.
This makes lots of sense. My mom's Volvo C70 had really thick door panels too and it was also a frameless window. There was a convertible option so these make sense. But I remember the doors being really wide.
Speaking of which are there other reasons to use a frameless window door vs a framed window door. Apart from the already mentioned convertible option. My Dodge Neon had frameless windows, and there was not a convertible option, and well at ~85 mph (~top speed) the windows would pull away from the seals and you would get a horrible vacuum sound. It was a nice distraction from the 'death shakes' the car gave off at that speed. If you were not ready for it you would think the car fell apart.
My dad's Subaru Outback also has frameless windows, with no convertible option.
My dad's Audi TT has frameless windows, but it is a convertible.
But I too want to ask what are the advantages to frameless windows, or rather framed windows? The only thing I can see is that frameless windows allow for convertible options.
The more I think about it, I really think Tesla will release a convertible Model S in the not-too-distant future. This paves the way for them to more easily do so without changing the body much. I feel like there was something else I noticed about the body that made me think this, as if they had planned it from the get go.
Aesthetics. They do look a bit better. But now that I do some research, it looks like a lot of people complain about the seals going over time with frameless windows, and that the windows also begin to rattle. This has me a bit concerned if this is a good choice on the part of Tesla if there's going to be long term consequences. They are also more easily to break into.
I do know my dad's TT (frameless windows) has adjustment on how high his windows roll up, how far they are angled into the car. He has had them adjusted a few times, but in reality his top is messed up so he won't ever get it to work perfectly. They are water tight but not air tight.
My C6 Corvette had frameless windows but they moved UP into a channel in the roof when you closed the door. This prevents the windows from flexing out at high speeds (the neon death rattle described above). They sealed perfectly fine because the roof became the frame. When you pushed the button to open the door (it also had electronic door handles like Model S) it would lower the window a fraction so you could open the door. Model S does this too. My only problem w/ frameless windows is that people use the window to close the door resulting in fingerprints.The only time I've driven a car with frameless windows, it was more prone to air leaks due to unreliable sealing between the window and the roof. The window seemed to flex out of place when there was a pressure differential (gust of wind, passing truck), releasing pressure on the seal and causing leakage. Mind you that was some years ago.
The Corvette worked on resistance to the motor so it would adjust automatically. Hopefully Model S works this way too.It is somewhat of a curious choice by Tesla given that noise suppression is key with how quiet the car will otherwise be. I think I'll have to be prepared to adjust the windows every so often as the seal degrades over time.
The more I think about it, I really think Tesla will release a convertible Model S in the not-too-distant future./
