Why can the Tesla app open the frunk but not the trunk?
El0n
76
70
Mars
Why is the shortcut on the Tesla app to open the frunk? Isn’t the trunk much more utilized?
Ant way to change the shortcut?
Wennfred
2,915
1,821
San Diego
I have the Auto Open Frunk mod so when I’m returning to the car with groceries I pop it open using the App. The Frunk also has the bag holders, I use those a lot.
Fred
Reactions: El0n
El0n
76
70
Mars
Because to open the trunk you have to manually lift it and there is a button on your car, under the lid. So, there is no need to get your phone out to open the trunk, why put a button there on the shortcut app.
Very true and you are very smart
SD_Engnr
1,836
1,489
San Diego
The trunk has a physical release button, while the frunk does not. Thus, the shortcut for the frunk. You can still use the app to open the trunk, it's just one more click into the "Controls" menu. Much easier than adding an auto-opening NFC tagged do-hicky.
sduck
Mr. Duck
Nov 6, 2017
1,388
1,394
Nashville TN
I just got the new fob, and didn't think I'd like this aspect of it, but I've used it to open the trunk and frunk several times in the days I've had it - very handy!
Runt8
1,986
2,371
Colorado
This is legit. I would totally use this .. if i knew how. LOL Any directions on how to add the NFC tags?
He had some instructions in the comments:
  1. Grab yourself a set of NFC215 tags from Amazon
  2. Download the ‘Remote for Tesla’ app
  3. Assuming you have an iPhone on iOS13 launch the ‘Shortcuts app’, hit the automation tab and create a new personal automation.
  4. Tap NFC
  5. Scan an NFC tag and name it
  6. Choose apps and find the Remote for Tesla app
  7. Choose open the frunk command (I decided for no confirmation open)
  8. Test it then place the NFC tag as pictured here: NFC tag Model 3 Frunk
3Krazy
28
25
Arizona
YOU CAN open the TRUNK from the Tesla app version 3.10.0. Under the "Controls" tab, you can open both frunk AND trunk. However, the Trunk open button does not appear on the home screen of the app as the Frunk open button does. Odd.
Reactions: Nocturnal
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
Did you read the OP's question?
They didn't ask if you CAN or CAN'T open the trunk from the app.
DopeGhoti
1,210
1,373
Phoenix, AZ
I don't even go into the app. If you expand the notification in Android, you get a shortcut right there for Unlock, Front Trunk, and Rear Trunk.
anti
56
56
SW WA
Yes, this is THE way to open the frunk. No confirmation and you don't even need to open the app or unlock your phone. For the trunk I always just lift it open.
DopeGhoti
1,210
1,373
Phoenix, AZ
Can someone elaborate on "expand the notification in Android"? I use Android, but not sure what that means.
Tap the downward pointing chevron in the Tesla app notfication, and it will expand, and look like this:
yerEVan
864
793
Near Philly
Honestly the title is a bit misleading, so i thought the same thing when i first read it. Also, the question in the body does not specify the home screen. I guess by typing “shortcut”, you could assume that though.
