Why can the Tesla app open the frunk but not the trunk?
novox77
1.21 Gigawatts
Nov 25, 2017
1,632
3,532
NH, MA
Also, doesn't this only work if the phone is within bluetooth range?
Nope, it uses the internet to talk to the car, the same way it does when using the app from outside of BT range to turn the HVAC on.
The commands in the Android notification area DOES require the phone-key BLE (bluetooth low energy) connection to function. If you only have a data connection, the commands in the notification go away (you get a message to enable BT instead), and you have to use the controls in the app to open t/frunk.
Also, if the phone isn't prompting for confirmation, then you're using the BLE direct connection. If you're relying on a data connection (tesla APIs), the app will ask for confirmation. Presumably this is because if you're close enough to issue the command, there's less of a security risk. But with just the data connection, you could be unlocking the car or opening the trunk from the other side of the earth. Could be a security issue if it were accidental :)
Reactions: SD_Engnr
DopeGhoti
1,210
1,373
Phoenix, AZ
Interesting. Tested this by turning Bluetooth off; the notification controls remains. I was able to Unlock the car, go into the app proper, and see that 'Unlock' had changed to 'Lock' as expected. Didn't feel like running outside to reclose the frunk, so I didn't test that, but I will before work tomorrow I suppose.
crackers8199
1,261
575
lake elsinore, ca
i have no idea how you have this working, it does not function like this for me. i just tested it - expanded the notification (while phone key connected), then turned off bluetooth. immediately the notification buttons went away. didn't come back until i turned bluetooth back on and the phone key reconnected.
DopeGhoti
1,210
1,373
Phoenix, AZ
Next you'll try to tell me that Teslas sometimes act inconsistently in the same situations. :)
Reactions: crackers8199
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
My Tesla phone app ALWAYS prompts me for a frunk/trunk open confirmation.
No matter if the app is Connected ( close ) or not ( far away ).
5_+JqckQttqck
1,851
1,336
Toronto
I'm not even sure how to access that. I'll have to look.
It's tricky to get to (if available on your phone - I have a SGS 7).
Settings > Apps > Tesla > Notifications > ON + App Icon Badges + Notifications + Phone Key Status (All on, various modes of alerts customizable).
The one that allows you to keep it on the status bar = Phone Key Status: Turn it on.
Reactions: Nocturnal
