STS-134
There's nothing in theory that would prevent a homeowner from installing 3ϕ electricity and then installing a DC fast charger in his or her garage. Just would require enough money and the proper permits. I tried to get a quote for 3ϕ service when I was doing my service upgrade (not for DC fast charging and not because I really needed it but because I was just curious about what it would cost) and was given a ballpark amount of "somewhere in the 6 figures". I ended up going with 400A peak/320A continuous split phase service which I could do for a cost in the very low 5 figures.120V home charging sucks, 32 Amp charging sucks less, 48Amp charging can still suck at times but its the best we got at the moment.
Of course, assuming I had a DC fast charger in my garage I would have used it probably exactly once (for testing) and actually needed it zero times. Not sure if I'd ever actually use it due to concerns about battery life. Plus, a single use during any given month would probably subject me to ridiculous demand charges as well.
I don't think you are allowed to put more continuous load on a panel or subpanel than 80% of its capacity. So 3 separate 48A EVSEs wouldn't be allowed even on a 150A panel. Since EVSEs are all continuous loads, they eat into your amperage budget much more than things like stoves, ovens, and dryers.Stand-alone 14-50 outlets and mobile connectors don't support load balancing, so if you decide to add another outlet at a later date, you might have to add a subpanel or run another line from a different breaker. Depending on the size of you panel/subpanel, you might have to manually ensure both weren't charging at the same time.
