If you have a rear wheel drive-system then you will want stagger (wider tires) for more rubber onto the road for better grip, small in the front for better handling, and lighter wheel in the front. Same can also be applied for front wheel drive, but less handling and you lose turning radius.
So it all depends on your car application. If your just using your tesla as a daily driver, stick with just OEM as if you do not properly setup your car correctly you may risk inefficient/imbalance of your car.
For simpler terms to understand. wider tires = more traction.
Not really - until some point. If you have larger tire it stays colder and there is always optimal temperature for maximum grip.For simpler terms to understand. wider tires = more traction.
At some size it reaches optimal grip from tire to pavement pressure, but it mostly matters during turns.
So wider tires can give less traction easily as well.
I run my model 3 on donuts from my ICE car, weight saving“We know that square setups are generally best for our cars”
Wait, don’t all tesla models have a staggered setup on the performance model?!
