To be clear, I'm aware that the emergency release only exists in the front doors. This thread is about the behavior of the electronic releases.
Try this experiment with your car:
I discovered this when I was showing off my new car to my dear sweet mother, who sat in the back. I told her "push the button, then push the door". She's an older woman who tends to think "step one, then step two". So she did what I said, she tapped the button, then pushed the door, which didn't work. (And the window down/up/down thing... it's just weird.)
It could be changed with software. To my knowledge there is no good reason for it to "re-latch" and raise the window half a second later, only to lower it again. Is this a glitch?
Why does this matter to me?? For my needs, I'll be using the car for commercial purposes, so I may have several people each day in the back seat, and for most of them it will be their first time in the rear seat of a Tesla. I realize I'll need to tell them "Push and HOLD the button while pushing on the door", which isn't actually necessary for the front. But I expect I'll have more confused people than I would if it worked like the front door. Not a big deal... but it could be fixed with software. And people like my Mom wouldn't be confused if they changed it.
I'm just wondering the REASON the rear doors behave differently? Or is there a reason at all? I tend to think it's just a glitch... Something they missed in development.
- At either front door, with your phone in hand, push and release the "fat" part of the door handle, but don't pull the handle.
As expected, the window will go down an inch, the door will move out an inch, and the door will swing freely out even if you just pull by the glass or the outer edge of the door.
- Now do the same with the rear door.
The window will go down an inch, the door will move out an inch, then the window will go back up again, then back down. The door will NOT swing out freely until you push the fat part of the door handle again.
- Now sit in either front seat with the door closed and "tap and release" the door opening button, but don't push the door out.
As before, the window goes down an inch, the door moves out an inch, and it will swing out freely if you push it.
- Now do the same from inside, in the rear seat. (Tap and release the button, with no pressure on the door.)
As before, the window goes down, the door moves out one inch, half a second later the window goes back up again, then back down, and the door is still latched unless you push the button a second time. You must push the door while holding the button, unlike the front.
- Now do the same again from inside the rear seat, (tap and release) but this time push the door out quickly, after releasing the button, but before the window goes back up.
Turns out the rear door IS fully unlatched during that half-second, and the window won't come back up this time. So it's not a mechanical issue due to different door geometry. Tesla software is literally raising the window again, re-latching the door, then lowering the window again.
