Well I’ve been a M3 LR owner for a year now and still learning! Getting to the point where I may change it while it’s got some decent value. Certainly a lot to learn about Tesla alternatives. However, for me, I do tend to plan journeys, so looking for maximum range with the shortest number/duration of stops. I’m not yet comfortable for a world without superchargers, but getting there. More to learn!
That was a super interesting read. Many thanksDifferent charging curve. It actually charges slower in total. Especially if you are talking about how many actual miles you get per time charging....
Correcting Audi: Tesla Model 3 Charges Over 2 Times Faster Than Audi e-tron
Audi used data from Twitter, messed it up, and inadvertently brings attention to the fact that the Tesla Model 3 charges over two times faster than e-troncleantechnica.com
I actually see it as completely the opposite. The test is "drive a distance and how long does it take to get back to the state of charge when you started". Now sure the Model 3 could go further before a charge, but if you looked at it as how many miles of range can the etron add in a given time compared to the Model 3, the e-tron wins. If you can avoid the stop altogether in the model 3 and not in the e-tron then the Tesla has an advantage, but I still think its a valid test.This is odd, given it's not comparing how quickly they charge in any meaningful way. If you're driving a distance you need an amount of range, not a percentage of battery. So charge them to the same remaining range and you're comparing meaningful charging. As others observed, the percentage is just different due to how much Audi chop off the top, to be able to say "look how quick ours charges at the top end" even though this makes the car worse for the end user as they have no option of trickle charging it higher for an extra hint of range at the start of a day of driving. On a side note, my speakers go up to 11...
A very interesting read. Thanks for posting. It’s almost like VAG have learnt nothing from DieselgateDifferent charging curve. It actually charges slower in total. Especially if you are talking about how many actual miles you get per time charging....
Fair alternative viewpoint. For me, the reason I don't think this way is that if I'm fast-charging it is because I am on a journey - overnight or whenever is when I aim to return the car to pre-journey state of charge. However, others may only feel happy setting off on any given leg of a journey with x% charge or whatever.I actually see it as completely the opposite. The test is "drive a distance and how long does it take to get back to the state of charge when you started". Now sure the Model 3 could go further before a charge, but if you looked at it as how many miles of range can the etron add in a given time compared to the Model 3, the e-tron wins. If you can avoid the stop altogether in the model 3 and not in the e-tron then the Tesla has an advantage, but I still think its a valid test.
Not using the top part of the battery is also better for the battery so for me, the e-tron wins on that too.
Heavily depends on the conditions. In the summer with battery temp at 30C, very little time saved by going to 50C for peak charging/performance. in the Winter with 10C, you get a big difference with preconditioning - assuming you start early enough.In the real world I'm not sure pre-conditioning buys much other than bragging rights to a high peak KW number for a few minutes. What you make in headline charging speed you lose in high energy consumption beforehand when it's pre-conditioning on the way. The rate it drains the battery in those 10 miles or so is alarming.
