There is a bug with
I have the same problem on my MY, but only since the latest sw upgrade to 2022.44.25.1 The release notes states something about adjusting the sensitivity of the sentry mode by using only sensors. Since then, default setting seems to be always on which is annoying
I noticed this bug too. While at
HOME, if I change the sentry mode setting from
OFF to
ON with checkmark
IGNORE HOME enabled, sentry mode is active and recording while at
HOME. If I drive away from
HOME and later return to
HOME, sentry mode will properly
IGNORE HOME and be
disabled. So, apparently this is a workaround for this bug and saves main battery drain from overnight Sentry Mode being active at
HOME.
This is a problem when you need to remove the storage device from the car's USB port. As there seems to be no way to
Eject the flash drive or SSD without corrupting the drive format. Before the
V10 update, there was a sentry mode Icon at the top of the center display screen for
temporarily disabling Sentry Mode. Now, I need to disable Sentry Mode from the Controls-Security menu. At least I have never found a new shortcut for that.
I just installed update
44.25.2, but haven't tried disabling Sentry Mode yet. So maybe they fixed this bug already. Something weird about Superchargers Icons not showing up on the map when dismissing the available Superchargers List.
