Your comment is perfect.This. When I drive my wife's Model S I feel like I'm in a luxury sedan that accelerates very fast. Driving my MYP feels like I'm in a very fast sports car that's a bit high and a bit heavy and alot of fun.
Ha. Not all of us live in a place where we have the opportunity to test drive. The Tesla stores I have been to while traveling don’t even have a Y there.Different strokes for different folks. I find the suspension fine on my MYP.
But kind of strange to buy the car first then complain about the ride quality afterwards. Seems like a lack of due diligence. Should have done some more test drives or requested an overnight tester. There are plenty of alternatives that may have suited your needs.
In any event, good luck.
This. I’ve had S loaners with air suspension. They ride like a dream. The last two Volvo’s I had (SPA XC90 & 60) were on air, and didn’t ride nearly as nice as the S on air.Have you driven an S/x? Their air suspensions are reportedly quite good. Tesla forewent them for cheaper traditional suspensions to save money in the 3 and Y.
Also, the suspension is fine on good, smooth roads (i.e. when it really doesn't have any work to do,) it just can't handle any imperfections. As the road surface worsens, the ride worsens exponentially. The roads near the closest Tesla service center are all in very good shape so you would have to do some searching to find a stretch that would really tax the suspension.Ha. Not all of us live in a place where we have the opportunity to test drive. The Tesla stores I have been to while traveling don’t even have a Y there.
The problem is, no one expects a small crossover SUV to ride or handle like a sports car. I expected the MY to ride more like an X5 or Q5. (Tesla itself actually says nothing on the MY web page.)Your comment is perfect.
MYP is a fun, do anything utility. That happens to peel your face off.
I plan to eventually put UPP sway bars and skid plates on mine.
I will admit, driving a friends M3 is what prompted me to order MY so I did have a test drive of sorts. I just can’t believe that people are so willing to call out the OP for saying he/she is not happy with ride quality. There are so many things you learn months after purchase that are not found in test drives.Pretty gutsy to purchase a car without test driving it. Can't rely on magazine/online/Reddit reviews. Ride quality is way too subjective.
Understood. Would be great if air suspension was offered as an option for the MY.I will admit, driving a friends M3 is what prompted me to order MY so I did have a test drive of sorts. I just can’t believe that people are so willing to call out the OP for saying he/she is not happy with ride quality. There are so many things you learn months after purchase that are not found in test drives.
I too think the ride should be better. I’m still going to buy the car. The only reason Tesla does not address the issue is because they don’t need to with the demand, not because it’s not an issue. There are so many good things about the car that outweigh the ride issue that it is still a good purchase but that doesn’t mean the ride is great or not an issue.
It’s very heavy and it has very quick acceleration and goes fast. Tradeoffs. If you want a smoother right get a model s.The model Y is a crossover, you would think they would put in a softer suspension for ride comfort. instead it's very hard and shallow. every road imperfection is felt through out the cabin. why doesn't tesla improve or use different suspensions supplier? i guess i'll just have to go after market *sigh*
i am on the gemini and it still sucks. i can't imagine daily driving with the performance 21" wheels
Skidplates are an all around good idea. Swaybars... not so much because you'd be adding more spring rate w/o compensating damping. The dampers also already have too much low speed compression as is.Your comment is perfect.
Your argument makes no sense either from the weight or the cost side. The Model S is actually heavier and faster than the Y. The Mach E tops out at over 4800 lbs, the Ioniq 5 weighs over 4400 lbs, and even the Audi Q5 weighs almost 4100 lbs yet all are cheaper and have better rides than the Model Y. Neither of the factors you mention are actual impediments.It’s very heavy and it has very quick acceleration and goes fast. Tradeoffs. If you want a smoother right get a model s.
You forgot to say: “in my opinion those rides are better.”Your argument makes no sense either from the weight or the cost side. The Model S is actually heavier and faster than the Y. The Mach E tops out at over 4800 lbs, the Ioniq 5 weighs over 4400 lbs, and even the Audi Q5 weighs almost 4100 lbs yet all are cheaper and have better rides than the Model Y. Neither of the factors you mention are actual impediments.
Actually, the only one of them that I’ve driven is the Q5 and it definitely rides better. On the others (including the S) I’m going by reports but I’ve seen zero reports that the the Y rides better than any of them. The best I’ve seen is something to the effect of “the ride is smoother in the Mach E but I really don’t mind the ride in the Y’ If you can find an objective review saying the ride of the MY is better, I’m interesed to see it. (I did edit my post to clarify, though)You forgot to say: “in my opinion those rides are better.”
See above.The Model S has air suspension.
Better based on what? The model y also accelerates faster than any of those cars so the suspension is more rigid.
Nice play with numbers now try again harder.Actually, the only one of them that I’ve driven is the Q5 and it definitely rides better. On the others (including the S) I’m going by reports but I’ve seen zero reports that the the Y rides better than any of them. The best I’ve seen is something to the effect of “the ride is smoother in the Mach E but I really don’t mind the ride in the Y’ If you can find an objective review saying the ride of the MY is better, I’m interesed to see it. (I did edit my post to clarify, though)
See above.
MYLR 0-60: 4.8 seconds
Mustang Mach E 0-60: 4.2 seconds
Hyondai Ioniq 5: 4.4 seconds
Even the Q5 can do 0-60 in 5.9 seconds.
They are all in the same ball park. Again, your arguments don’t hold up.
Love how you pick and choose to help your narrative, just like CNN.Actually, the only one of them that I’ve driven is the Q5 and it definitely rides better. On the others (including the S) I’m going by reports but I’ve seen zero reports that the the Y rides better than any of them. The best I’ve seen is something to the effect of “the ride is smoother in the Mach E but I really don’t mind the ride in the Y’ If you can find an objective review saying the ride of the MY is better, I’m interesed to see it. (I did edit my post to clarify, though)
See above.
