So why is there a "loop" for interior heating? Just heat the air.
I probably should have said system instead of loop. The interior loop is only for cooling.
How is it you have a heat pump given the leaf doesn't have active battery cooling?My leaf worked great in the frigid north called Chicago. I think heat pumps are probably something Tesla should consider but they seem to be stuck on a Cali mindset. Its a definite point of weakness when compared to my lowly Leaf.
Tesla probably figures that by the time a heat pump would kick in, the battery would be warm and their system for harvesting excess heat from the battery cooling system is even more efficient than a heat pump would be.
Heat-Pump Cabin HeaterHow is it you have a heat pump given the leaf doesn't have active battery cooling?
The leaf has passive battery cooling and a battery heater for extreme cold. It seems to work just fine.
I don't expect 20 years from my leaf but 10 would be nice. I need at least 10 from the S for it not to be a giant waste of money.
Do Nissan Leafs have better range in the winter than other EV's?
EV1's and S10 EV's used heatpumps. GM decided that they were not the solution apparently. Nissan perhaps did not get the memo?
Actually Nissan originally made the LEAF without a heat pump (just resistive heating) and then added a heat pump in later LEAF models to improve its efficiency.
Heat pumps are heavier, more complex, and less effective at super low temps.
But did it actually improve their winter range? How much?
hmm, well I'm basing my facts off of data from the manufacturers, but I guess they could be wrong and our beliefs could be more accurateI don't believe that a Model S' interior area is double that of a LEAF. I own both. Model S is maybe (being generous) 20% larger (not counting Frunk). The hatch storage area is about 40% larger in the S than the LEAF but the interior cabin is not that much larger. I put a car seat in both cars (The same car seat) and it fits about the same. Honestly I was disappointed that the S wasn't significantly larger (its wider and a bit longer on the inside). Vastly larger is a very incorrect characterization.
At this point in the conversation, I was simply referencing the section of the car with the most noticeable difference......the cargo area alone of the Model S is double that of a Leaf...
And here, you stuck with the point, but were incorrect with your guessing....The hatch storage area is about 40% larger in the S than the LEAF...
Now this is were I used actual facts instead of opinions to further the conversation...."The (2016) Leaf has 23.6 cubic feet of cargo space behind its rear seat. That number increases to 30 cubic feet with the standard 60/40-split rear seat folded."
"The 2016 Model S has 26.3 cubic feet of cargo room behind its rear seats and 58.1 cubic feet with them folded."
That works out to 1.94 times larger, or 94% larger.
2012 Model S: <all the same specs>
2012 Leaf: 14.5 cubic feet behind rear seats. 24 cubic feet with rear seats folded down.
That works out to 2.42 times larger, or 142% larger.. .
Uh-oh, this is the part where you were called-out and now want to change the point of reference, and try to be witty by using quotes you see on the television....I dunno why you are focused on only the rear hatch storage but your math is based on an alternative fact...
hmm, it may be time to replace the batteries in your calculator (reference actual numbers above that support the original point that was being made), and refine your reasoning skills (30% is not almost exactly 40%)....Btw that's 30% or almost exactly what I guessed...
