Modern heat pumps are significantly more efficient than resistant heat down to -22F. People who think heat pumps don't work in cold climates are basing their information off 1990's knowledge.
Really? Air source heat pumps? I wasn't aware of that.Modern heat pumps are significantly more efficient than resistant heat down to -22F. People who think heat pumps don't work in cold climates are basing their information off 1990's knowledge.
^^THIS!^^I just wish I had a heater-off button... ...I really hate it when I am too warm and I try to blow cool outside air in the car and it heats it even though I have the heater set to "Lo".
I hardly ever use my heater. I just wish I had a heater-off button so that I could just blow outside air on the windshield to defog it, no heating needed. And I really hate it when I am too warm and I try to blow cool outside air in the car and it heats it even though I have the heater set to "Lo".
Does that really not use heat? The manual is unclear, it just says that the second touch (red) operates "the heating and fan at their maximum level." it doesn't say that the first touch is no heat and, since the climate control system seems to be on whenever the defroster is on, my assumption is that the heater is being used. I'll try to measure it sometime.It does this already, the first time you press defrost you get a blue icon.
The windshield defroster distributes air flow to the windshield. Touch once to turn on, touch a second time to operate the heating and fan at their maximum level, and touch a third time to turn off and restore the air distribution, heating, and fan to their previous settings.
Tesla is going to have to add a heat pump to compete. The LEAF & Soul have one too.
Hyundai Ioniq has a heat pump too.Beating a dead horse. I dread winter again. The AC is so efficient compared to the heater. Luckily my family can take a bit of cold during long car trips. Our leaf is so toasty and so efficient but so not a road trip car...
I'd love to know what air-source heat pump is actually more efficient than resistive heat at -22F, however, while producing anything remotely like its rated output.
I'd love to know what air-source heat pump is actually more efficient than resistive heat at -22F, however, while producing anything remotely like its rated output. There have been multi-stage designs like the Hallowell Acadia that claimed to go that low, but they're inherently larger and less reliable than mainstream designs. Even the most efficient units from Daikin, Mitsubishi, etc. are rated only down to -15F, and while they might eke out a COP above 1 at those temperatures, they also produce far, far less heat than their rated capacity -- so unless they're massively oversized, supplemental (read "resistive") heat will still be required, basically any time you're at about 5F or below.
I think you are missing the capacity. The COP may be better than 1, but if it is producing at significantly lower than the rated kW capacity, then the heat output (kW) will be lower (even though it is more efficient). Efficiency aside, that is what you feel in terms of how "strong" the heat is.Greater than 1 is better than any resistance heater will do. 1.1 is already great. I'll take 10% better over nothing anyday.
I think you are missing the capacity. The COP may be better than 1, but if it is producing at significantly lower than the rated kW capacity, then the heat output (kW) will be lower (even though it is more efficiency). Efficiency aside, that is what you feel in terms of how "strong" the heat is.
That's why the supplemental resistive heat must be used even though it has a lower COP.
Here's a link to the latest Mitsubishi model (first manufactured 2016):Or the capacity high enough not to care. None of the state-of-the-art heat pumps use backup heat. Backup heat is a 2000's problem, not a 2017 problem. I don't have backup heat in my house.
The heating capacity at -25C (-13F) (figure 5 page 12) drops to 45% of rated.
https://nonul.mylinkdrive.com/files/PUMY-P60NKMU1_-BS_Service_Manual.pdf
It still has a aux heat setting.
Sure, you can buy one twice the capacity rather than use an aux heat, but I don't see how newer ones had eliminated the core issue of a massive drop in capacity at lower temperatures.
