It could be. The 4-9 plan may be better for some over the Prime. It depends on how much you use, when you use it, and many other variables. The best thing to do is look at your history of usage and compare it to your solar production.
I was on the 4-9 plan originally. But because of the morning marine layer and when we run our pool pump, the prime ended up saving me money in the long run. For you the 4-9 may be better.
I was just clarifying that the 4-9 is not always the best for all people, as well as the misconception that higher rate plans pays you higher rate for production (which it doesn't.) Net metering is only 1:1 for production matching usage. Any net over production is wholesale and is paid at the same wholesale rates for all plans. The baseline credit does give you additional production money based on what your allocation is.
For anyone new to this, they should try to the 4-9 plan first since that is what they automatically sent you up with anyway. Monitor you usage and see what it would be if you went to the Prime. Then determine which is better
Agreed, it's a complicated set of factors to calculate the best plan, it would probably change if you only look at partial year usage.
As soon as my PW was turned on, I switched to D-Prime. I was on the grandfathered 2pm-8pm plan before that, and looking back I could have stayed on that for longer.
But in my case, since I also switched to heatpump central heat, I'm going to be net using quite of lot of energy during the winter months when PV production is low, and I don't yet know if I'll be net positive for the year to be able to save enough credit to cover it all.
I have a smallish set of panels, so I should have enough to charge the PW to avoid peak usage in the winter, but I still need the cheapest power from the grid in the morning.
All the other plans have a mid level cost from 8am, so I'd have to fully heat the house before that for best cost performance.
Going partially back to the main question of this thread though:
Once you have a battery and manage your daily usage and electric plan to benefit from it the most, what happens if part of the system goes down?
I had this problem back in March - one of my inverters broke, leaving 5kW of panels offline for over 3 weeks.
That was leaving me pulling power at peak times, so my careful plans of aiming for a zero usage power bill were blown up.
I had to do some zen breathing to get through that - "it'll all be worth it when it's fixed".
