Would love to see you do a little write-up here on the form comparing the handling and driving pleasure of these two icons.
E92 M3 suspension with the active dampers was a dream. It didn't really give anything up to comfort due to the active damper programs even with (relatively) stiff springs.
It's all about the dampers. Everyone tries to upgrade springs because they don't know how dampers work.
edit - oh and I USED the s*** out of it on regular roads. One touch of the M button put the suspension in sport stiffness in something like 10 milliseconds. One of my most missed features in this upgrade. That and M stability control programs.
I think the point he was trying to make was how much of that improved handling performance can you actually use on the the street since you can't take your car to it's limit generally ever.
For instance, I owned a 2006 M5 and then bought a 2010 M-Sport 535 which I proceeded to tune and put down something like 470hp from the crank. The M5 was the better car still, no doubt and on a road course it would have beat the 535 with little fuss however on the street neither car came close to approaching it's limits in terms of handling which meant that in the real world, the 535 could do 99% of what the M5 could because the M5 wasn't in a position to take advantage of it's better components. Couple that with the significantly better low end power of the twin turbo 535 and the 535 ended up being a better street car in almost every way.
...+ wasn't an option ....:crying:
staggered RE71Rs make a P pretty close to a + besides the tilt
I'll challenge anyone in a stock E92 M3 in autocross. P85 is a bit quicker + better balanced to put down power
How much do +'s lean compared to this pic? I only got to drive a + in mostly wet and couldn't get a feel of the stiffness difference.
can I put a + sway bar on a P without other minor changes? if anyone knows
I only got up to "warning" over 5 years. The brakes saved me from more tickets than the engine could try for. It is a torqueless wonder compared to the P90D. Reminds me, I do miss those brakes too. Cross-drilled floating rotors.Don't know where you live, but you're lucky if you get to drive it hard on the street. There's NO WAY to do it safely and not get thrown in jail where I live.
I agree completely. Our tuned 335 was much better as a daily driver than my M3. Some people equate stiffer/firmer ride as better handling, and that's true to some extent, but not all the time. And most Tesla owners will NOT be happy with the stiffer ride on a daily basis.
nuch of which is likely just a result of the larger wheels/ tires anyhow.
M.
I really enjoy the P85D handling. It is a good balance for an everyday commuter. I would only consider handling improvements if it does not impact my nice quiet ride in the morning.
Usually track focused cars are horrible street cars.
Running on 245/275 19"s, pretty sure they get at least 10% more cornering grip than PSS's - (check my signature link for some more)Autocrossing an MS!! Well done sir!!
What size wheels/tires are you using? Those RE71 are suppose to stick like fly paper.
I never hear the front engine when not using range mode. The car is much more silent since it has better soundproofing than the older cars but that is the same for a new P85 build from around September 2014.Your ride isn't all that quiet with the whine from the front drive train. My P85+ is much quieter than a "D".
4wd is the most important feature on a car for me and will never buy a car without it Just sad with a powerfull car without grip and useless i the winter where I live.
When comparing other Model Ss to the +, I hope most people are at least driving then with stock 8.5x21" rims. The only difference the + gives you are rear tires that are just 3/4" wider on each side and 9x21" rims. That's it.
I swapped out my rear rims for stock 8.5" rims so I could buy cheaper matching 245mm tires and rotate them front to back and noticed zero change in handling.
I thought the "+" also gave you stiffer suspension bushings, different sway bars, higher spring rates and also firmer shock valving.
I don't believe you'll actually achieve the 3/4" improvement in contact patch, since the tire is mounted on a wheel that's too narrow. Though someone will have to actually measure to find out.
Huh? The 265s are mounted on 9" rims. The 245s are mounted on 8.5" rims.
The additional 3/4" is just the increased width of the tire spec, I wasn't really even talking about contact patch, as that is also a function of car weight and tire pressure.
My point is if you increase the rim by 0.5" and the tire spec by 0.75", you're not getting 0.75" more useful tire. You could in fact mount the same 245 tire on the 9" and get more contact patch.
The P85+ suspension is amazing and makes the car handle like it weighs half. There is no better way to make a 4,600 lb car feel like a much smaller, nimbler and more maneuverable car than by giving it the + suspension bits. Unfortunately, I don't like where Tesla is going. The only practical difference between a P90DL and a 85D is acceleration. Seems like there should be more for the huge difference in price.
