Ludicrous Mode happened because the P85D is limited by the amount of current it can push through the contactors and fuses. Ludicrous Mode upgrades those to handle more current.
The P85 is likely not limited by the current capacity of the contactors and fuses, but by other factors like traction and inverter/motor power. Upgrading the contactors and fuses would therefore be possible, but wouldn't allow for any increase in performance.
Thanks for the input. In JB Straubel's blog about Dual Motor he states that "[FONT=HeiS ASC Simplified Chinese, HeiS ASC Simplified Chinese_n5, HelveticaNeue-Regular, Helvetica Neue Regular, Helvetica Neue, Helvetica]
The shaft horsepower rating of the rear wheel drive single motor Model S is straightforward and roughly 360-470 hp depending on the variant (60, 85 or P85). Also, it is generally similar, but not the same, as the battery electrical "horsepower" output." The 'but not the same' suggests that there may be some benefit from changing to the ludicrous contactor. While the improvement may not be as large as with the P85D, it may still provide a performance improvement ([/FONT]
I am less convinced that my P85 is limited because of traction, especially when I can improve traction with bigger tires).[FONT=HeiS ASC Simplified Chinese, HeiS ASC Simplified Chinese_n5, HelveticaNeue-Regular, Helvetica Neue Regular, Helvetica Neue, Helvetica][/FONT]
