Why is my HPWC red instead of green?
Discussion in 'Model X: Battery & Charging' started by SSD420, Jul 10, 2016.
  1. SSD420
    SSD420 Member
    ON, Canada
    image.jpeg Ive owned my Model X for two days. Used my HPWC three times. I just got home and instead of shining green it's shining red (see pic). Is this bad? What does it mean?
  2. SSD420
    SSD420 Member
    ON, Canada
    :(:(I switched the switch in the breaker installed next to the HPWC off and then on again. Tried that. Went to a moving green and my car charge port turned orange. My app showed it charging at a mere 16A.
    I proceeded to unplug the charger and plug it back in and now it's working again. I'm at 72A.
    Can anyone explain what happened? Or what I did wrong?
    And of course I'm still in love :D in my Model X (even though it got its first scratch, totally my fault :()
  3. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I always pray that my first scratch is a little one. Then I know the car will be OK. I've had some big first scratches...those por car souls. They tried. But it just wasn't their time...
  4. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
  5. commasign
    commasign Active Member
    Davis, CA
    Cylons? K.I.T.T.?
    j/k. Did you try pressing the reset button on the left side of the HPWC?
  6. xkwizit
    xkwizit Member
    Folsom, CA, United States
    Just press the reset and it will clear it out.
  7. SSD420
    SSD420 Member
    ON, Canada
    There's a reset button?
  8. SSD420
    SSD420 Member
    ON, Canada
    Yes, it's the new one.
  9. commasign
    Davis, CA
    Yes. This one.
    OMG. This literally looks like a Cylon's head especially if the light is red.
  10. SSD420
    SSD420 Member
    ON, Canada
    Thanks guys
  11. ProtoMM
    ProtoMM Member
    Philadelphia, PA
    It may go without saying, but just in case... If this happens more than once in a very great while, you should get the electrician back to fix things. Routinely clearing a detected electrical fault wouldn't be good.
  12. SSD420
    SSD420 Member
    ON, Canada
    What would you consider to be a "great while?"
    It was installed about 10 days before I took delivery and installed by the Tesla recommended electricians. How many times does this need to happen until I should get the electricians back?
  13. X Fan
    X Fan Supporting Member
    Naples, FL & OIB, NC
    If was me, one more time.
    Old one has worked flawless for me since installation....
  14. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    It's a cylon. I hope everyone is watching The 100. The AI reminds me of Caprica.
  15. SSD420
    SSD420 Member
    ON, Canada
    The 100 is great!
  16. vandacca
    vandacca ReActive Member
    Hamilton
    #16 vandacca, Jul 11, 2016
    I have the same issue and I have contacted Tesla. Whenever power is applied, it goes through the startup sequence and finishes with a solid red light. The manual says, don't retry and contact Tesla immediately. They sent over an Electrician and the install was fine, but they were concerned about proper grounding at my main panel. They "addressed" the grounding, but it didn't help.
    I can hold down the reset for 2 seconds and I get a green light too. However, the electrician's current plan is to get a new WC and swap it out. I'll wait and see if that helps.
  17. SabrToothSqrl
    PA
    I wouldn't go that far... Season 1 and 2 were rocky, but Clarke is a bad ass and I love her for it.
  18. SSD420
    SSD420 Member
    ON, Canada
    You're not all caught up?
  19. SSD420
    SSD420 Member
    ON, Canada
    I'll see what happens this week and monitor it. If it continues to happen. I'll contact tesla.
  20. SMSMD
    SMSMD Active Member
    Edmonton, Alberta, Canada
    why dont you call your electrician and see if the L1, L2/N and GND are tightly screwed , had read on the forum someone had a similar problem and the it was loose screws on the conductors. Check dial settings on the left side to the correct breaker size you are using and make sure the DIP switch is DOWN (1) and UP (2) upload_2016-7-12_0-12-22.png
