h2ofun
Mine will look like that when clouds come over.Temps in the high 60s.
I would be fine with this. Look at the first post to see what ours looks like.
If it were cloudy I would have no issue. The issue is similar graphs occur on numerous bright and sunny days.Mine will look like that when clouds come over.View attachment 653569
I am not saying I know the answer, but there were times I thought there were no clouds, but when I looked closer, at times they were way up there. Just have to keep collecting dataIf it were cloudy I would have no issue. The issue is similar graphs occur on numerous bright and sunny days.
The roof is not particularly steep. It is easy to walk up and down without fear of slipping (at least when dry).I think there is something wrong with your production. The peak does not seem high enough for that size if system. That said, does your roof have a steep pitch?
No way can one say system size expects X. Directions. Angles, shading, etc. I will never get close to my spec size because of these type of thingsI would have Tesla investigate. This seems WAY too low for a 12kw system.
This is an apples to oranges comparison, but here is what my 16 kw SunPower system produced on that day (peaked at 14.7 kw):
yo J, I know you to be a really smart engineer, so maybe you have thought about this... I wonder if what you are seeing is the same thing I see on my house down in San Diego. Half my modules are facing West and half of them somewhat South. Reason for the West facing modules is to get power in the later afternoon due to the TOU schedule.Hi,
I was looking at the graphs for our SolarRoof's production and noticed that the top is getting cut off. The roof has a total rating of 12.75 kW and the South facing portion is 8 kW. Both the north and south-facing roof planes are in complete sunlight. I have verified there is no shading on any part of the roof during the period in question. Any thoughts?
Here is the graph from yesterday which was sunny from 7-ish AM on.
That is a good thought. The house faces North/South almost perfectly and we do have active tiles on both sides. So something to consider.yo J, I know you to be a really smart engineer, so maybe you have thought about this... I wonder if what you are seeing is the same thing I see on my house down in San Diego. Half my modules are facing West and half of them somewhat South. Reason for the West facing modules is to get power in the later afternoon due to the TOU schedule.
What happens down there is that around mid day as the sun starts showing less on the South panels, the energy drops from those, but is balanced out by the West facing panels getting more sun. This happens for a period of about an hour or more. And small variations in the curve where it flattens is due to minor variation in the atmosphere, temperature, etc. So I am wonder since I think you mentioned having panels facing different directions if this is part of the reason for the flattened curve? Your graph does look somewhat like my home down south, and I know that system is working perfectly.
The system is a solar roof with about 8kW on South facing roof and the remainder on North facing. We did have days of 80+ kWh but closer to the equinox.I would have Tesla investigate. This seems WAY too low for a 12kw system.
Something definitely seems low. I know we are on the other side of the country, but our 8.2 kW roof (4.1 kW each N and S) is producing as much or more than your 35 kWh number on sunny days. With a combination of the lengthening days towards the solstice (I'm assuming that's when you are hitting 80+ kWh) we have had several days this month above 35 kWh, and the max we have ever hit was 43 kWh (though we got PTO in July, so some June days might have produced more if running on-grid), so barely over half what you have seen. And I have not seen anywhere near that level of fluctuation in output on a truely sunny day.The system is a solar roof with about 8kW on South facing roof and the remainder on North facing. We did have days of 80+ kWh but closer to the equinox.
Yeah, based on the low production, I guessed earlier that maybe the smaller inverter wasn't working (or at least a string or two). Less than 50% is way too low at this time of the year. Our system was at 50% vs. last year's max production over two months ago, in the first week of February. Currently our system producing at 91% of last year's maximum production. We did have some issues last year with dirty power causing our Powerwalls to kick in a lot (like 3 dozen times a day) and shut down our solar system, so it's possible our maximum production will be a lot higher this year. Taking that into account and estimating a new maximum production value, our system is currently producing at least 75% of last year's peak production and we hit 50% back in the third week of February.We are only 9 weeks or so from the equinox right now, and you are less than half of that 80 kwh. Something just doesn't smell right on this one.
You might try contacting some of the members, such as @Bozon and @jat255 , who've posted in Delta M-4, String drops out to zero for 2 hrs ? and who are reporting production issues with their Delta-M inverters. I think at least a couple posters have app access (M Professional?) which lets them see which strings aren't producing. I have 3 Delta Solivia inverters, not the M series, so I haven't bothered trying download the app or try to monitor string production yet.There seems to be a consensus that we should be producing more and perhaps the inverters are not correct. I tried turning them off one by one and the production does drop on inverter shutdown, and climb back up when I bring each inverter back online. So at this high level of testing the inverters are outputting. Is there a way to test them further, or is it time to have Tesla check it out? Perhaps I should take a phone down there with the Delta app and let it record for a day?
If you use the M Professional app, connect with the "6532" code, and activate the advanced features, you should be able to see historical data for the past 10 days for each string and also see the inverter log.Perhaps I should take a phone down there with the Delta app and let it record for a day?
