Why is the trunk button grayed out unless the driver's door is open?
Discussion in 'Model S: User Interface' started by Barry, Jan 29, 2016.
  1. Barry
    Barry Active Member
    Colorado
    If the car is in Park, one should be able to open the trunk from the 17" screen.
    And is that new with 7.1 or did I just never notice it before.
  2. green1
    green1 Active Member
    Calgary, Alberta, Canada
    I think it must be new in 7.1, because I'm pretty sure I don't have that limitation on 7.0
    7.1 should be named "nanny mode" I'm sure this is in response to all the people who claimed that the whole third of the dash lighting up to tell you your trunk was open wasn't a big enough warning and to try to prevent people from opening the trunk while driving and not noticing!
  3. Max*
    Max* Charging
    NoVa
    I'm 100% sure that limitation didn't exist in v7.0.
  4. green1
    I frequently pop the trunk for friends when I pick them up or drop them off, all without getting out of the car, it would be silly for me to open my door first.
  5. trils0n
    trils0n 2013 P85
    SF Bay Area
    I have 7.1. I can open the trunk when the car is in park. Don't need to open the driver door. Maybe a reboot is in order? I'm noticing lots of weird little bugs in 7.1.
  6. Max*
    Max* Charging
    NoVa
    I just went to try it, OP is wrong, sort of.
    When you press park, the car is still locked and the trunk is locked, you need to press to park again to unlock the car. Once the car unlocks, you can open the trunk.
  7. green1
    That's new. In 7.0 when you press park everything unlocks.
  8. Barry
    Barry Active Member
    Colorado
    Thanks Max. I give that a shot next time I'm in the car.
  9. kevincwelch
    kevincwelch Active Member
    Chicagoland
    Alternately you can hit the little lock icon on the console and accomplish the same thing. I didn't realize the "double park" would do the trick. Probably easier.
  10. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    The car must be in park, and unlocked, which the first caused the latter in 7.0.
    However, I also would like to be able to open the trunk without unlocking the car. I'm IN the car. If I push open, it means I want to open the trunk. Even my 7 year old Tahoe does this fine...
  11. CuriousG
    CuriousG Active Member
    Elk Grove, CA
    I was going to say I didn't notice this being an issue at all. I then realized that when I'm doing this I usually have a passenger that has exited the vehicle which unlocks the doors.
  12. AudubonB
    AudubonB Investing is fun!
    I have 7.1, and just went out to emulate your observation. For five minutes, I could not duplicate it...until I altered, in "Settings", some of the vehicle's Auto-lock options.
    There is child-lock, driver-only or all-door, lock on walkaway, etc., as I'm sure all of you are aware.
    WE keep all of these options in the miminum security set-up. It was only when I altered them to some more secure possibility that the Trunk Remains Locked gray screen the OP mentions came into being, so it appears it's a feature of that.
  13. LetsGoFast
    LetsGoFast Active Member
    Virginia
    It is a setting: > Settings > Vehicle > Unlock On Park.
    If you have it set to ON, the car unlocks when you go into park and the trunk can be opened. If you it set to OFF, you have to hit park again or open a door. Depending on your other settings, opening a door may not unlock the rest of them either.
  14. AudubonB
    Right - that's the one I meant when I wrote "lock on walkaway". Thanks for the clarification.
  15. Barry
    Barry Active Member
    Colorado
    I have Unlock on Park OFF, for security. If anyone wants to get out of the car, it doesn't matter. If someone is waiting to get in, it's easy enough to press Park a second time or press the Lock icon. I can deal with the inconvenience of unlocking first if I want to open the trunk (though I don't understand why they changed that; it's up there with removing the Media Source button) now that I know why it's happening.
