Here's where the confusion lies: the pull-stalk-and-hold action has different meanings depending on context. There are several cases, but two will illustrate the problem.
Case 1: TACC is engaged and is holding the current set speed (the triangular bug on the speedo). If the solid or dotted tick mark representing the speed-limit-plus-offset is displayed at any speed other than the current set speed, pull-and-hold resets the current set speed to the new speed, and the car accelerates or decelerates to the new set speed.
Case 2: TACC is disengaged and the driver controls the car's speed with the go pedal; the triangular bug and the tick mark are displayed at two different speeds. Pull-and-hold does not reset the current set speed to the speed-limit-plus-offset (tick mark), but instead re-engages TACC at the 'old' set speed (triangular bug).
Why Tesla implemented this modal behavior is unknown, and frustrating to me. What happens frequently is that I disengage TACC with braking (as at a traffic light), then encounter a change in the speed limit and watch the tick mark move in response, and attempt to use pull-and-hold to re-engage TACC at the tick mark (as in Case 1) only to realize it's accelerating to the old set speed instead.
