(moderator note - split off from another thread on minimum amps needed)
If one had to upgrade, why not consider going to a 400 amp serviceHow about posting your load calculation?
Service means connection from the utility. If you currently have a 100A underground service, there's a possibility that the service conductors are large enough for a 125A service without changing. If you have to upgrade to a 200A underground service, that is quite expensive in PG&E territory.
Cheers, Wayne
