Why slower than Model S? Just a typo on Tesla's page?
Discussion in 'Model X: Battery & Charging' started by DriverOne, Dec 26, 2016.
  1. DriverOne
    DriverOne Supporting Member
    Austin, TX
    Tesla's custom order page for Model S tells me "The included Mobile Connector can charge at a maximum of 40 amps, allowing up to 29 miles of range per hour."
    The same page for Model X says, "The included Mobile Connector can charge at a maximum of 40 amps, allowing up to 25 miles of range per hour."
    29 for the Model S, but only 25 for X? Why is that?
  2. Ben W
    Ben W P85 #61, Roadster #108
    Santa Barbara, CA
    The Model X is bigger and heavier than the Model S, so it takes more electricity to drive the Model X one mile than it does for the Model S. So the same hour's worth of electricity at 40 amps is enough for 29 miles in the Model S, but only 25 miles in the Model X.
  3. GSP
    GSP Member
    The X uses more energy per mile than the S. The battery will load energy at the same rate (Charger power is the same), but it takes more Wh/mi to drive the X. I don't know if that is responsible for the entire difference, but it is at least part of it.
    GSP
  4. DriverOne
    Austin, TX
    Oh right, good point. Never thought of it that way. What is the rated Wh/m for the X? Around 350 I guess from the 29->25 change.
  5. Sparktz
    Sparktz S 90D, X 90D
    United States
    I think it depends on your specs (75D vs 90D vs P90D/P100D).
