Ulmo
From a design perspective, the engineering behind the Chademo adapter is probably akin to the engineering behind a similar CCS adapter.I think you are confusing AC vs DC charging.
An adapter between Tesla and J1772 AC charging is trivial because the pins and protocols are identical except for the physical plug design.
An adapter between Tesla and CCS is much more involved. CCS DC charging is the effectively the same regardless of USA type 1 CCS or European type 2 CCS plug format. The signaling protocols and messages are the same between the two CCS DC plug designs, I'm pretty sure.
Tesla's DC protocols are actually closer to CHAdeMO since they seem to use similar, but perhaps not identical, signaling that is based on the so-called CAN bus design that is typically used to network together internal computers and components even within conventional cars. However, Tesla does not seem to use the same CHAdeMO messaging between the car and the DC charger on top of CAN.
The CCS uses a completely different signaling system for DC charging called PLC and sends messages on that data transmission layer using the same tcp/ip protocols that the Internet is based on. The actual messages sent between the car and the DC charger are unique to CCS.
I see two routes in the future, both being implemented by Tesla: (1) Tesla creates a CCS->Tesla adapter with built-in signalling conversion (much like Chademo), for use with CCS fast charging to legacy (all current) Model S & X, sold for around $700 ea. (2) Tesla also introduces additional hardware into all new Model S, Model X and all Model 3 as well as any redesigned Roadster to do the necessary signalling (ethernet modem), and includes in the car charger bundle a CCS->Tesla adapter plug, at a fraction of the cost and complexity as their (1) CCS->Tesla adapter, sold for around $20 ea. Both will exist on the Tesla shop for decades. Software in all Tesla cars (old and new Model S & X, Model 3, etc.) will be upgraded to talk CCS logic to CCS chargers (such as having tcp/ip stacks, CCS protocols, authentication, billing, etc.), whether or not the signalling modem is in-car (2) or in-adapter (1). (Some of the software/firmware for the ethernet & tcp/ip and even the CCS protocol handling can be put into the physical area of the modem, or not. Kind of irrelevant from an outside perspective --- just as long as Tesla is consistent enough about it to make it easy on themselves to engineer reliably.)
For those who have both a new car with new modem hardware and an expensive adapter for old cars, I suppose a compatibility mode from the car would just choose one of the modems to use. That would save someone $20 when they trade in their old $80K car for a new $80K car AND loose the $20 converter plug. Silly footnote. Software-wise it would be trivial, though, so I threw it in here for comprehension's sake.
How far off am I?
