For Ludicrous+ you need [Max Battery] to warm the battery for best efficiency/lowest cell IR.
So when you select Max Battery why do the fans run at full speed to cool it then?
To heat and cool the battery as necessary to keep it as close as possible to the optimal temperature for maximum performanceFor Ludicrous+ you need [Max Battery] to warm the battery for best efficiency/lowest cell IR.
Yup.....it's for the "turbo" modeerrr.... so the battery doesn't burst into flames?!
No. That wouldn't make sense.
Umm.... get some extra boost from the fans maybe?
Maybe that explains the Taycan Turbo trim level...they should follow Tesla's lead and have the cooling fans come on full blast, may amplify them with the sound system when ever Turbo is called for...Yup.....it's for the "turbo" mode
I figure it’s heating the battery and cooling the motors. Someone with a CAN scanner would be able to see for sure.
But why simultaneous warming and cooling and over apparently wide temp range?To heat and cool the battery as necessary to keep it as close as possible to the optimal temperature for maximum performance
I don't think it's batterygate. Batterygate has the constant-fans temperature set point extremely low. It's essentially always-on fans at any SOC above ~69% (the faked 69%, so really it's more like 55-60%). I wonder if the 'certain temp' just happens to be below the L+ mode pre-heat?
They aren't just trying to stop the battery from getting too warm normally as you drive, they are trying to stop the battery from warming itself up even when it's parked and sleeping - that's when the cooling system used to be inactive, but batterygate batteries will continually heat up from tiny internal short circuits constantly heating up one cell until it reaches the critical point and sets off a chain reaction.
