Got my battery tender and can confirm that there is no range loss overnight when the 12V is on the tender.
I was thinking of wiring in a charging cable to the jump posts of the 12V battery behind the nose cone. Does anyone know the size of the nut I have to get at the local hardware store. It looks like it is threaded. The purpose is to put in a cable and run it through to the frunk to add on another battery in parallel OR run it below and add on the battery tender on occasion. I want to avoid pulling off the nose cone to frequently.
I'm going a different way and will use a battery tender whenever the car is parked at the house. This will reduce the discharge cycles and should let the battery live much longer.
I've had a CTEK 7002 tender for my classic car for years and it has done a great job, so I just ordered a second one for the Tesla. It's beefy for a tender at 7A so it will keep the 12V battery charged even with the vampire drain. I'm thinking having the tender hooked up I won't lose any range over night either which is a bonus.
You're in luck as I just did this. The negative stud behind the nose cone is M8-1.25. The positive already has a nut that you can reuse. Strangely enough the positive stud is SAE.
I cut a hole on the bottom of the nose cone and stuck part of the CTEK quick connector through it. Epoxy on the inside to hold it in place. The CTEK is bolted to my work bench next to the car, so when I park the car it's only a couple seconds to plug in the tender.
Ingineer said: ↑
BTW, it's a simple matter to keep the 12v outlet in the console live all the time if desired.
It's just a simple relay in fuse box #2 (the one on the passenger side under the removable cowling cover - see owner’s manual).
Simply make up a jumper consisting of short piece of 14AWG or better wire with a couple of male 1/4" spade terminals. Pull the front most passenger side relay out and insert the jumper into the now exposed 1/4" female receptacles, and you're done, the 12v outlet is now on all the time. You can quickly change it back anytime by removing the jumper and reinstalling the relay.
Ford Energis (both models) initially had 12 vt issues and people were modding the original battery compartment with a larger battery before Ford 'fixed' the issue. Ford went through a few dead cars with charged HVB but the 12 vt was dead. I forget the exact reason the car was killing the LVB, but I think they blamed bad batteries.
