It's always nice to meet a like minded person in the area, thank you for the feedback. We definitely have a lot to learn with video editing and every bit of feedback will help us improve the quality of the next video.
Sure thing. The hard part is what you're doing well, content! The easy part is the technical side, and your audio will be easy to improve. You may also need separate lavalier mics for each of you, or two desktop mics (Blue Yetis work well if you want a good USB solution). Otherwise, one of you sounds close and intimate and the other sounds distant, especially if their speaking patterns naturally end in trailing volume.
Speaking or vocal performance is just something that comes from experience and confidence, but one also has to be aware that this is important and work on it too.
It's quite normal for the performance to be shaky when you're first vlogging—talking to yourself in a quiet room at 9p or whenever you did this. As you realize you're talking to real people, you'll generally snap in to that performance mode at some point (and it's better to do this earlier than later so your videos get more views and good feedback). This performance is just best-practices as it relates to being heard and understood, with viewer engagement; confidence, projecting your voice (yes, even with a mic), using mic imaging (closer to mic for quieter speech, farther out for extremely loud speech), good diction, etc. You may not need to image the mic for normal speech but if you watch vocalists, this is an important technique. Better to know about it than not.
I'm a singer too so that helps, hehe.
After you get a good recording with good signal you can post-process it for compression and normalization (and EQ if you need or want it).
If you read a script it's going to sound like that and few can get away with it. There are times when this is perfectly appropriate, such as reading a headling, a news blurb, a comment, etc., but I wouldn't do a whole vlog this way unless your reading is top notch and sounds natural. For maximum engagement, I think it's better to have bullet points of talking points you want to hit and then use extemporaneous speech to hit those bullet points whilst allowing for a bit of riffing, humor, etc.
In the last post I meant to write 'comment' instead of common. I thought I fixed it but it didn't take I guess.
Good luck with the channel!
