shrspeedblade
Rideshare Monkey
I'm not sure how to measure range loss because I wasn't monitoring range or kw/mi before. I got the V9 update a couple of weeks ago, and it varies between 150 and 300 depending how I drive, maybe average at 200? I don't notice any difference between this and my old tire. My motivation to change the tire was that the stock tires are not grippy enough when I accelerate out of turns, and I was nervous doing high speed turns on mountain roads with the stock tires. Since I don't drive anywhere cold I knew I could get summer performance tires. Also I wanted to improve the stopping distance for hard braking for emergency. Price at Costco for all 4 installed was $940 which includes 9.5% sales tax and I got my old tires back in bags. Regarding MPH vs GPS take a look at my original post above and you'll see that it's only 1MPH difference, so that's negligible.
No I don't notice any visual difference but my friends at work said the new tires look better and bigger and more aggressive. To me they just look like my old tires, but I feel safer driving around with the better grip and I can drive more confidently. So getting the Pilot 4S definitely delivered on grip but I'm not sure how the 235 and 245 size would have been different.
I too was hoping the larger sidewall would mean some increased ride comfort over bumps, but I don't think it made a difference. I use around 40PSI . I don't notice any difference in noise either.
These tires were an expensive upgrade, but I wanted the extra grip and driving confidence since the car is so powerful. The tires will probably wear out after driving 20K miles on them so I only recommend doing this if you're willing to spend extra money on tires every 2 years instead of every 4 years. Maybe if I keep up with rotations due to RWD I can drive them 30K miles.
I assume the aero covers will still fit?
Really interested to know your wh/mile after several thousand miles.
Also, if anything I've found the stock speedo to be a little under compared to the radar stations in my area, which have been quite accurate with other cars, so the slight increase in diameter could make it more accurate!
