Wifi enabled charging
Discussion in 'Model S: Battery & Charging' started by docbrown, Jul 8, 2018.
  1. docbrown
    docbrown Member
    Austin, TX
    My city utility gives a larger rebate on charging installation if the wall connector is wifi enabled. As far as i know the Tesla wall connector cannot be wifi enabled, is this correct?
    If i go with something like the Juicebox, is there any disadvantage of this over the Tesla connector?
  2. BrettS
    BrettS Member
    Orlando, FL
    The Tesla HWPC is definitely not able to be connected to the internet or managed remotely.
    In my opinion the only downsides to using a third party J1772 charger are that you would need to use the J1772 to Tesla adapter each time you charge and that you don’t have a button on the charger to open the charge port door. You could always get a second J1772 to Tesla adapter to leave permanently installed on the charger, but that would eat into the money you saved by going with the third party option.
  3. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Well, *technicallty’, it’s connected to the car, which is connected to the Internet... :D (When it’s plugged into the car, it can be upgraded, etc., so therefore, it’s ‘connected’.)
    What’s their rationale for this increased benefit for ‘connected’ EVSE’s? Some perceived more-useful technology down the road? Because on the face of it, they are prescribing themselves on paper out of recognizing ones like the HPWC that don’t use wifi but are connected, as I said. This is a perfect example of people that don’t know what they are doing writing ‘specs’ in regulations.
  4. Cebe
    Cebe Member
    Canada
    If the utility can control when your car is charging, that's worth money to them...
  5. docbrown
    docbrown Member
    Austin, TX
    I’m assuming that the utility company will remotely control the power usage when they need to. They do the same thing with wifi thermostats.
  6. boaterva
    Ah, *they* want to control it, like the Air Conditioners some utilities can shut down in the daytime. Well, that makes more sense.
    And I doubt I’d want my utility messing with my car.
    And I’ve never heard of a utility having access to a wifi thermostat. Details?
  7. boaterva
  8. docbrown
    docbrown Member
    Austin, TX
    Yeah I've never signed up for their thermostat program, I don't like the idea of the utility messing with my AC settings. And I'll probably just go ahead with the Tesla wall connector.
  9. JD01
    JD01 Member
    Chicago
    Another thing to consider is that most of the 3rd party options max out at 32 amps. The HPWC can go much higher if you have juice.
    With that said, I loved my ChargePoint. It worked well and I could share it with all EV owners. If I needed to, I could shut it off remotely. As a bonus, it sent data to my Nest so all of my charging was nicely wrapped up in a monthly report that told me exactly how much electricity Scarlett was chugging and estimated how much it cost. The app gave me daily and monthly breakdowns as well which was awesome when you're trying to explain the benefits of an EV to an ICE owner.
    The only reason I switched was the wifey. We traded her car for an M3 and I quickly realized that sharing the charger with her was a major PITA. Getting 2 HPWC's and putting them both on my existing circuit was significantly less expensive than buying a 2nd ChargePoint and running another circuit to it. Plus, it's a 60 amp circuit so I was able to set them to 48 amps and charge faster.
    FYI: I'd strongly recommend getting a 2nd adapter if you go this route. The convenience is more than worth it.
  10. rhumbliner
    rhumbliner Member
    Jackson.Hole Las.Vegas
    I signed up for a similar program in Las Vegas and it seems to work pretty well. I believe I save $20 - $30 per summer month and the house isn’t noticeably warmer. They cap the setback at 4° but the most I’ve observed is 2°.
  11. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Our utility has the program called "A/C Cool Credit", which doesn't do anything related to anyone's thermostats in their houses. They just have a box that they install on the outside electrical line of the A/C unit itself. It's like a wireless relay, so they can remotely power off people's A/C units on some rotating schedule for 15 minutes at a time.
