I've searched and read all the threads on people with model 3s and wifi issues, and have never had any success in getting mine to reliably connect, since day one. In fact, I've had a service ticket in for 2 months now over it. Yesterday the mobile tech finally made it out, so i thought I'd document some of what we found.
Background - I work in the consumer electronics industry and do a lot of work specifically with and around wifi and wifi testing. My home currently has 5 hardwired access points. 3 ubiquiti unifi, an Asus RT-AC68U, and an xfinity DOCISS 3.1. The unifi is my primary system, I use the Asus for testing, and comcast refuses to allow you to disable the xfinity. I have a unifi AP ~18 feet from where my car is parked, mounted to the ceiling, with one wall between. The ASUS is about 30 feet away, through 2 walls.
The car, since I took delivery, has been unable to see ANY of my APs. Sitting in the car, using my phone (OnePlus 6T), i can see 12 APs (neighbors + my own) with decent signal level. I could get it to tether to my phone with the phone in the car, with poor signal.
The service tech that came out did some testing and swapped passenger side mirror assemblies (the antenna is in there, if you didn't know. We got it connect to my unifi system (yay!) and I went back in to check the connection out. Unifi was reporting a -48dBm connection - outstanding. Problem solved. The tech said he tested the old assembly and it tested good, but he didn't specify how he tested it, or what good was. But since it was working now, great! While he was reassembling the car, though, I noticed that after placing the mirror assembly cover back on the indicator in the car went from full signal to low. Checking back on the Unifi controller, it was now reporting -62dBm. The car was not moved, nothing changed but the replacement of the cover.
After the tech left, I moved the car to various locations and angles in my driveway and checked signal levels. When backed in (passenger side of car facing house and AP, antenna facing AWAY) i got very poor connection -85dBm, but it was still connecting. When pulling straight in (antenna opposite side of car from AP, angled at ~35 degrees away from AP) it will not connect at all. At an angle in the driveway, with the antenna facing directly towards the AP, I can get the same -62dBm I got when the tech was there.
Really long story, summarized: I don't know what material the mirror assembly cover is made of, but it's blocking ~14dBm of signal at 90 degrees. That is not insignificant. The location of the antenna - front side of the assembly, angled to follow the curve of the assembly - also may play a factor. I didn't get to examine the antenna itself, but the radiation pattern does not look optimal. This may also be caused by the material of the cover - at oblique angles more of the material is between the antenna and AP.
