Wifi signal is weak inside the car but its strong outside the car
Discussion in 'Model S' started by Eswar M, Dec 25, 2016.
Tags:
  1. Eswar M
    Eswar M Member
    Dallas
    In my garage, speediest on iPhone shows very good speed (40mbps) but when i test it inside the car it drops to less than 1mbps. Router is inside the home diagonally above the garage (15-20ft).
    Does it mean i need to get a range extender for my garage to boost the signal for garage ? has anybody experienced this ?
  2. sdorn
    sdorn Director of Awesome
    Georgia
    I believe the car is designed to block radio signals (the windshield for sure). That might be part of the issue.
  3. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    Faraday' cage :)
  4. Polyport
    Polyport Member
    SLC, UT
    How many bars does the wifi symbol show on the 17" screen when you connect your Tesla to your Wifi? If you get connectivity, you don't need a range extender. As far as I know the antenna for Wifi is in the right side mirror (so not inside the car).
    Also, even if the speed is slow, it'll still be enough to download the occasional updates. The car downloads any available updates and only when they're completely downloaded does it show you that an update is available for install, so you're not waiting longer for an install with a slow internet connection than with a fast one.
  5. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    The OP is not talking about the car connectivity, rather iPhone connection within the car in the garage.
  6. Polyport
    Polyport Member
    SLC, UT
    He might, but since it was his first post (which implies that he's at the initial "lets make sure my car has everything it needs" stage) and since people don't typically often sit in their car in the garage using their phone, I assumed he was worried about his car not getting good wifi. I could be wrong.
  7. mspohr
    mspohr Well-Known Member
    Only if you sit in your car in the garage and browse on you iPhone.
    The car itself has an external antenna located in the driver side mirror so it should receive the WiFi signal just fine. You can run a (non-flash speed test from the Tesla browser) to check it.
  8. Eswar M
    Eswar M Member
    Dallas
    Forgot to mention. The actual problem is tesla wifi is SINGLE bar. I was troubleshooting it and tested the the signal strength with iPhone.
    I want to know what i can do to improve the tesla wifi signal reception.
  9. Polyport
    Polyport Member
    SLC, UT
    Single bar is fine. As I mentioned in my earlier post, the download speed doesn't really matter much, it'll still download any updates. No need to add any wifi infrastructure. As @mspohr suggested, you can run a non-flash speed test on the car's browser if you're curious. But as long as you can pull up any webpage in the car's browser, it'll be good enough for downloading updates.
  10. Eswar M
    Eswar M Member
    Dallas
    Sometimes its so weak that it takes lot of time to open a web page. Just tried the non-flash speed test in tesla browser and I see 2mbps download speed. Would that be fine for it to download updates?
  11. Polyport
    Polyport Member
    SLC, UT
    I don't get any faster speeds with my car and I get my updates just fine. Your car has all night to download, while it's parked. Also remember, it doesn't require wifi to download updates, it will use 3G/LTE, too. (For map updates, happening once in a blue moon, it will strongly prefer wifi, though)
  12. Eswar M
    Eswar M Member
    Dallas
    Thanks for the information @Polyport !
  13. doubleohwhat
    doubleohwhat Member
    Alabama
    Also keep in mind that Tesla throttles the download speed of updates. I have an access point directly above the car and we have a gigabit connection. However, the map update that came through the other day downloaded at almost exactly 8mbps.
    Basically I wouldn't worry about making sure the car has a speedy connection because it's most likely not going to use it anyway.
  14. Dstrohl
    Dstrohl Member
    Seattle Area
    I cant speak from experience in terms of how much this impacts (or doesn't impact) updates, but I will say that if you are testing from your phone, and if your access point is newer than 4-5 years, it is very likely that even if you have the same signal levels on both, your phone is going to be faster. The Tesla's do not use any of the standards or frequencies that newer systems support (though supposedly the Tesla hardware supports them). For example, the iPhone has supported the "ac" standard since version 6, 5Ghz frequencies since version 5, and has supported "n" since version 4. I don't know if the Teslas' can handle "n" or not, but they definitely do not handle 5 Ghz channels or the "ac" standard. (at least mine doesn't show any of my 5Ghz access points)
  15. lunitiks
    lunitiks Cool James & Black Teacher
    Prawn Island, VC
    Njet. Passenger side mirror.
  16. bkp_duke
    bkp_duke Active Member
    San Diego, CA
    Actually, both mirrors.
  17. BerTX
    BerTX Supporting Member
    Texas/Washington
    I put in a range extender. $18 from Amazon. I like to use the nav to plot trips to different places, and look for new Supercharger availability. I also use the Tesla app to change charge settings and climate control. It's painfully slow or impossible for me with a weak wifi connection.
    I do use other tools for trip planning, but I like verifying it in the car and having the first leg of the trip already entered in the nav to look at it and verify it isn't doing something stupid.
  18. lunitiks
    Prawn Island, VC
    That's GSM. Wifi only right mirror
  19. Eswar M
    Eswar M Member
    Dallas
    I got a NETGEAR genie (only 2.4GHz) to test out how much i can give to Tesla. You are right. Non flash speed test download speed came around 8mbps. I was thinking of getting a little higher speed one thinking that Tesla can take more than 8mbps. But if the download speeds are throttled then then i will keep it.
  20. Eswar M
    Eswar M Member
    Dallas
    Yes. Having better wifi speed in garage really helps. With poor wifi reception, I have to wait to enter destination into nav until i get onto street which is inconvenient and not safe.
