Is anyone else connecting to a Plume or similar mesh network? I finally got electricity into my detached garage (ongoing house renovation), and added a Plume pod out there, so the WiFi signal in the garage itself is strong, but the node actually has a very weak uplink to the rest of the mesh, and the car won't connect to it. I got the car to connect once in the past with the Plume pod on an extension cord into the part of the house closest to the garage, but that quit working, and now that the pod is actually in the garage, it won't connect. Doesn't give any error, just times out and gives up.
(for those that don't know, Plume uses a large number of low-power nodes called pods, rather than a small number of higher-power mesh nodes. The idea is that you have less signal spillage out of the network, but the downside is that extending the mesh to my garage is stretching the limits of the system. It seems to me like the car shouldn't realize that, though -- it should see a strong WiFi signal, and not care that the AP giving it that signal has a really weak uplink)
