Wifi
Discussion in 'Model X' started by Sandiegodoug, Jun 17, 2017.
Tags:
  1. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    new owner here. Just wondering if most owners connect to home wifi?
    Does it help with updates?
    Is it going to really slow down our system, or does car communicate at night when we are sleeping. Finally, once set up, lf I set up, does it connect automatically when I pull into garage?
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    I do.
    Updates go by an unknown priority list so some will get it first, others not.
    But to download a file or an update, of course I would prefer wifi rather slow 3g or 4g.
    I heard that map updates only for wifi.
    I have no idea but I imagine it would but updates don't happen every week or month.
    Yes.
    You can manually turn off your car wifi but it then automatically connects to your wifi once your car is restarted again.
  3. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Thanks
    Maybe I'll connect it as delivery told me it uses At&T network which is poor signal at our house.
  4. TessieX
    TessieX Member
    Arizona
    I've connected mine... haven't noticed any slowing of data for the family (5 people sucking in as much useless internet information as they possibly can).
  5. rjdoc74
    rjdoc74 Member
    LA, CA
    I live in a condo and don't connect to wifi. My wifi signal does not get to my garage. Had 2 updates so far with no issues.
  6. chillaban
    chillaban Active Member
    Bay Area
    You may get updates on the order of days or a week or two earlier on wifi compared to LTE. It seems like updates get tagged with metadata that states whether or not to wait for wifi download, how long to wait, and what to do if that time passes. Most updates are marked to download anyway at the end of the period.
    Of course everyone here is OCD about having the latest update so we definitely connect to wifi and try to do every voodoo trick we know to get the update.
  7. AnxietyRanger
    AnxietyRanger Well-Known Member
    EU
    In my Model S days, for whatever reason, I used to get updates much slower over Wi-Fi. (It had full bars in the car and a nearby antenna, so that should not have been a reason...) So much so that I eventually turned it off from the car, because I kept getting updates only on 3G... I know Tesla claims the opposite (it is in their interest that people avoid the mobile connection, after all), that Wi-Fi helps the speeds, but just noting that this has not always been my experience. Actually I could swear I also received a maps update over 3G on the Model S, even though I know Tesla says not...
    That said, I would use Wi-Fi and see how it works for you - I see little harm in trying. I turn it on/off on occasion still these days as well...
    Some notes and links to my experiences with Tesla + Wi-Fi here: How much data is Wi-Fi transferring?
  8. Insight75
    Insight75 Member
    Mount Olive, New Jersey
    I use WIFI. I figure maybe if more people use WIFI, they won't eventually start charging for cellular
  9. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    I connected
    Do they send an email letting us know
    Or it just shows up?
  10. Insight75
    Insight75 Member
    It just shows up one day. You'll get a message on the screen asking if you want to update. It could take a while and you can't drive until complete. Keep this in mind if you are in a hurry.
  11. Hugh Mannity
    Hugh Mannity Mediocre Member
    Port Haney, BC
    That's a good point. Keep the charges from Tesla as much as possible and we may enjoy the lack of subscription going forward.
  12. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    If you don't update how do you find updates
    So you can update when your sleeping
  13. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    When there is a message on the screen that an update is available, the car has actually already downloaded the update. All it asks you is to set a time to install it. It defaults to the middle of the night, which is the best time to install it as you won't be tempted to "check on it" and screw things up. The car needs to be left alone when it's updating.
    If you haven't connected to wifi at home, you will keep getting prompts asking you to so. There's no reason not to and it saves Tesla's data expenses. Also map updates are so large that they are only sent by wifi. That doesn't happen often, I think I've had three in four years.
  14. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Thank you
    None of this was explained at pickup
    He said we didn't need to connect to wifi
    I thought I read that I needed to.
    I'm not a tech person so car is a little intimidating, but like my iPhone I'll figure it out eventually. Most amazing car I've ever driven.
  15. TexasEV
    Austin, TX
    Reading the manual might help.
  16. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    Put the Tesla app on yer iPhone with notifications ON, then you'll be let know when update is ready and when finished.
