Will 4' x 4' plywood fit in model S?
Tam
8,261
7,114
Visalia, CA
Pretty sure it won't in GLC
I don't have my Model S anymore but when I did, I measured the length from the rear central A/C vents and it was about 76" which could easily accommodate one side of your 4x4' plywood.
However, the trunk's width was only about 39" so you cannot lay your 4x4' plywood down flat.
I imagine you can tilt your 4x4' plywood to fit it in the Model S.
hemants
117
4
toronto
Are you sure?
I don't see a way to get it through the rear door, there is no dimension even close to 4'!
Likewise diagonal seems 45" max
Tezzie
147
45
Southern California
Are you sure?
On the diagonal (front to back as well as side to side), it can barely fit. To be safe, I prefer putting it vertically behind the back seats better, because I don't want to mess up my upholstery.
Don't EVER try to put a bale of alfalfa in the back of a Model S. You can jam it in there, but you'll have to take it out piece by piece. It's a nightmare, I speak from personal experience. Took 2 months to remove all the alfalfa bits.
Reactions: aerodyne and Tam
