Yes. Details of "yes": I have a Specialized S-Works Venge (road bike), 56 cm, and I am 5'9". Why the details? Because it is a tight fit and if you are very tall, your results may vary.
Yes. Details of "yes": I have a Specialized S-Works Venge (road bike), 56 cm, and I am 5'9". Why the details? Because it is a tight fit and if you are very tall, you're results may vary.
Spent to much on getting fitted to risk removing the seat, I am riding a 51.5 Pinarello which is like a 54 in any other brand. Im 5'09 as well... so sounds like it will fit with no problem. I know the Venge has a lot of top tube slope so there is more seat post exposed than my setup.. Thank you for the replies!
I'm 6'1" so my frame is a little bigger. What I should have said was to remove the seat and seat post as a unit. I do this all the time to put my bike in tight spaces. If you mark the seat post at the top of the seat tube. It's pretty easy to get it back within a fraction of a millimeter; I can't imagine a fraction of a mm upsetting any fit.
