rcc
Model S 85KW, VIN #2236
Yep - buying a Chademo adapter makes sense if you have a specific need and Chademo will work for you.
I wouldn't buy it otherwise except in Japan where Nissan has tried hard to blanket the country. Sheer numbers of chargers installed don't tell the story. The problem with Chademo is given that it's used primarily by EVs with <70 miles of real-world range, you have to space them 50 miles apart instead of 150 miles if you're going to cover the same straight line distance as an SC. Say along I-5 between SF and LA. 3x more chargers. The number is a square of that (9x) if you need to cover a circular area instead of a straight line.
And it gets worse when you consider that with long-range cars like the S, you charge at home, drive all day and only need Supercharging if you're going on a road trip or a long day-trip. And given the choice between using a Chademo or SC for a road-trip charge, SC's are better because they're faster.
So most Model S owners don't need any charging that's not at home.
The upshot is that Tesla needs to build far far fewer Superchargers to get effective coverage of the entire country or just the major cities and highways than is needed for Chademo. Chademo will never ever get there. Not even in the major cities.
And once you can buy a 400 mile EV for $30K, Chademo will just fade away.
