Silly question, but I don't have my home charger yet, and I don't have any 220v outlets in my house. I just want to get through the first week of driving around town without going to a supercharger. I'll plug it into a 120v line to keep it as charged as I can until an electrician actually calls back (why is this always a problem?) I finally found a plumber that responds, but never an electrician. At least call back and say sorry, I can't do it.
Haha same problem with me.. finally found an electrician and I feel he’s over charging me but I need it done and he’s one of the few I found fully licensed and insured. I’m sure they come fully charged.
Mine didn’t come fully charged. I got a SR+ and I think there were 150 miles left. I was also using the regular 120V until I got a hold of an electrician and also ordered a JuiceBox. It was like 5-6 miles per hour with 120V.
I would be surprised if you didn't have 240vac somewhere in the home, but sure, some don't. I guess you now that if you have an electric dryer rather than gas, that would be 240. Cars come mostly charged, but it is greatly variable depending on the area. Not common to be "fully" charged.
Most new deliveries do not come fully charged. The delivery centers don’t have Superchargers so they rely on the wall connectors which can only charge up to 44 mph. On busy days they may only have an hour or two to keep the cars plugged in before they move on to their next delivery. Even slow charging on 120v should be enough to keep you going unless you are driving more than 60 miles per day. Just keep it plugged in whenever you are home.
You can ask that your Tesla be fully charged, but they do not have the capacity to top up every delivery. Most want to try Supercharging as soon as they get delivery. See if there is a Supercharger nearby on on your way home to fill as desired. Also check to see if your delivery center has a destination charger in their parking lot you can use. Check your house to see if your have a 240V socket you can use until you get your charging set up. Purchase an adaptor for that socket and run a heavy duty extension cord to your car. Might be a dryer or kitchen stove that has a socket you can use. Last option is to simply plug into a nearby 120V outlet and put in the hours necessary to get your charge. Tesla recommends you get your charging set up prior to taking delivery.
My house unfortunately does not have any 220v outlets. My dryer, stove, heat and water heater are gas, and these usually need higher voltage/amps if electric. I know the house is capable though. In fact, a few years ago one of the lines into the house went out at the street and Con Edison came and bridged the two lines temporarily so I had power. They then came months later to finish the job and get me back to dual feeds. Their one concern was that I would lose any 220v appliances if they did that but we had none. There is a supercharger not too far from me, maybe 3 miles from home, but this is Brooklyn and 3 miles can sometimes feel like 30! In the meantime I'll keep it plugged into the 120v outlet on a 20amp circuit. I figure it'll be in the driveway at least 12-16 hours each day anyway. I'm not using it to commute, and that was true even before the pandemic, and before I retired. It'll be joy rides the first week.
My car was given a quick charge before delivery. Cost was 4.65. I have free supercharging through June of this year.... didn’t matter in my case.
My 2018 LR RWD was delivered to our home with ZERO miles of range remaining. We had to run an extension cord out to the truck and charge at 120v for 30 minutes before we were able to drive it off the truck. Fortunately, after over two years of ownership, there has been almost no apparent loss of range (306 miles, more or less, both then and now). I feel your pain IRT finding an electrician. I called one who had done work for us in the past, but he was tied up with new construction. I spent one week calling others with no luck. I called my guy back and he agreed to do the installation when he finished the big job he was working on--one month later. Fortunately, I had made my initial call to the electrician on the day the car was ordered, so in spite of the delay, 240v was available when the car arrived.
Mine was delivered with 28% remaining. I'm about 25 miles away from the Fremont factory. I use 110v as my primary charging, as I almost never need full range on back to back days. I charge to 80%. If I ever need more than this, SuperChargers or even Evgo/Plugshare/Chargepoint are pretty convenient. 240v is a nice to have, not a necessity. Also worth noting that batteries prefer being charged slowly.
The Kansas City center charged my wife's to 100% last week but we had the first pickup appt that day. I'd previously mentioned we had a 5 hr driver home.
Mine had 90% SOC on pickup and I used 120v for a few weeks until permits were approved and my electrician could come over. Since I am working from home, 120v worked fine. It was slow to recover on the couple times I took the SOC down the low 30s. But worked out fine.
By now, you’ve probably learned that charging to 100% is a no-no, unless you plan on driving the car immediately. Asking for your brand new Tesla to be charged to 100% for delivery is either being ignorant of the long term damage to the battery, or simply not caring. If you have a long drive where range could be an issue, perhaps you could call them ahead of time and ask they charge it to 90%. Most people are looking forward to charging their new car for the first time. Some are anxious to try supercharging, and others have spent a significant amount of money to install a wall charger at home that they want to test out. What would be the fun if you get home with a 97% charge remaining? For what it’s worth, my car came charged around 60%.
As you can probably tell by the responses, there is no telling what the SoC will be. What I can tell you though is that I didn't have to pay for supercharging on delivery day. This is true for both the M3s I purchased. Supercharging on your way home is probably your best option. Even if you had to pay for the charge, chances are it's less than $10.
It came with 90% charge, which is what they recommend anyway. The delivery guy said they send out all of their cars that way. The charger was on the wall right next to my car.
Picked mine up at the Fremont delivery center, it was at 80% Sounds like anywhere from 20% - 90% is possible though
variable. mine was in freight for 2 weeks before it got to me and arrived with 88%. presume it lost 2% while asleep for 2 weeks.
