Will it fit for Winter wheel for 2015 Model S 85D, 19 inch, Replika R163A
Discussion in 'Model S: Driving Dynamics' started by T3MTLCanada, Oct 13, 2018.
  1. T3MTLCanada
    T3MTLCanada Member
    Montreal
    Hi,
    I saw an wheel I like, the silver color. I need this for winter.
    I found this:
    Replika - R163A - Polished
    I put my vehicule information and it said it fit my car.
    Replika R163A (Painted/Hyper Silver) Wheels 19x8.5, 5/120 Offset: 35
    4.8
    (5) Reviews
    Price Range: $170.99 to $181.99
    FITS YOUR
    2015 Tesla S 4 Dr Sedan Base (245/45R19 98 V)
    (Change Vehicle)
    But the center bore on those wheel is 72.6. Normally the Center bore should be 64.1.
    Will these fit me car? Do i need to add anything else to make it fit?
    I will reuse tesla lug nut and logo for the middle Hub.
    Thanks!
  2. Corsair
    Corsair Member
    South Surrey, BC , Canada
    It will fit but you won't be able to use the Tesla logo caps (too small 64.1mm vs 72.6mm)
    PMC Tire is pretty good. Once you placed an order, they will follow up with a phone call and would advise whether you need special vs factory lugs.
    Ps. I bought Braelin BR02 from them which needed special lugs.
  3. T3MTLCanada
    T3MTLCanada Member
    Montreal
    will those work? Center hub ring 64.1mm ID to 72.6mm OD ? to fit the tesla logo?
  4. Doanster1
    Doanster1 Member
    Oregon
    Yes, those hub-centering rings are what you need. BTW, center bore has nothing to do with the center cap size. They are not the same size. You just need to ask the vendor whether the replicas will accept the stock center cap. Better yet, ask them what size cap it fits.
  5. Russell
    Russell Supporting Member
    Silicon Valley
  6. f-stop
    f-stop Active Member
    Vancouver BC, Canada
    if your original Tesla caps don't fit your 3rd party wheels, you could get these Tesla logo'ed stickers: 3dcarstickers
    Available in any diameter you specify, just measure the caps that come with your wheels. The stickers are covered in a thick, domed resin - Happy with mine, they look good and are still holding up well, like new.
