Will MX fit in my garage?
Discussion in 'Model X' started by ohmman, Sep 8, 2015.
Tags:
  1. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    I haven't noticed a change. Is this the first time you've seen that happen? Do you have your suspension geofenced to low in your location? Even if you do, I have noticed that when parked, the suspension setting isn't always obeyed. This occurs with my S and my X.
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    I don't have my suspension geofenced to a specific setting at my location, as long as my suspension remains on standard (or below) a impact shouldn't occur. I haven't tested high or very high but its probable those two settings would result in an impact.
    I would assume the X does not automatically adjust to high or very high on its own? However, when I exit the car after driving (park in the garage) I hear the suspension make noise, likewise when I reverse the car from park it makes noise again.
  3. ohmman
    North Bay, CA
    I would make the same assumption, but I wouldn't rely on it.
    As far as the suspension noise, I think that's what I was talking about above. When in park/off, there's some stable suspension level. When you're in gear, it changes to "normal." Search the S threads for air suspension - there are a lot of people who agree that it seems to act randomly. For instance, in my Model S, if I raise it to "very high" to clear a concrete parking block, park, shop, and return, it'll lower itself to "normal" as soon as I put it in reverse, and come down on the parking block.
    My unfortunate suggestion is to never open your garage door while your falcon wing doors are already open. Mine open in restricted mode but I still don't chance it.
  4. K-MTG
    Irvine, CA
    I had umbrella mode enabled but it resulted in some occasional impacts to my head when I exited the driver's door so I enabled always fully open at this location for my garage. I actually try to make sure I only open the Falcon Wing Doors when my garage is already open but they are times when I inadvertently end up opening them.
  5. vandacca
    vandacca ReActive Member
    Hamilton
    It's my experience/understanding that suspension levels are geo-fenced only for high and very-high. You can't geo-fence low or very-low. It would be awesome if my X would go into very-low every time I parked in my garage, but it doesn't do that today.
  6. outie
    outie Active Member
    SoCal
    I requested the feature to have low/lower geofenced few months ago. If you want the feature please make sure to request it!
  7. ohmman
    North Bay, CA
    I've requested geofenced door height setting that takes into account suspension height. So basically max height of X based on location. That was a few months back.
  8. Aljohn
    Aljohn Member
    Georgia
    Interesting..... I back my X into the garage to avoid the opener and rails. May want to give that a try.....(watch the mirrors on the single door garage!!!) That's just a suggestion if power and other things permit.
  9. ssq
    ssq Member
    Guys, my X doesn't open the the driver side FWD fully despite having ample space above and on the sides. Anyone else see this behavior? It used to a few months back, I got the sensors checked, to no avail.
  10. ohmman
    North Bay, CA
    Do an override open (hold until fully open) and select "always open fully in this location" once it appears. Or have you already done that?
  11. hahler2
    hahler2 Member
    South Dakota
    So I'm doing some measuring to see how a Model X would fit in my garage. Floor to garage door rails is 87.5 and floor to the garage door when it's open is 91. So I don't see any issues with the FWD. However, the way our garage is laid out we need to be able to walk in front of the vehicles. So we always park as far back as possible so that the door just clears and maximize the space in front of the car. When I do that I only have roughly 84 inches of clearance at the back for the lift gate. If the lift gate is fully open what is the clearance? I haven't been able to find that measurement online.
  12. araxara
    araxara S-P85#3,218 X-LR M3AWD
    Tucson, AZ
    I don't have the lift gate measurements handy, but the lift gate can be programmed to stop at a certain height.
  13. hahler2
    hahler2 Member
    South Dakota
    Yup. I was just curious how it would work out.
  14. mal_tsla
    mal_tsla Member
    Austin, TX
    I just measured the liftgate fully open, it's about 7'7, or 91" off the ground at the highest point. At 84" you won't want to open that thing fully.
    To allow it to open fully (ok, really just for peace of mind), we had the garage door rails changed to high lift tracks. They go straight up another foot before turning towards the garage. Plenty of room, cost about ~$200
  15. mal_tsla
    mal_tsla Member
    Austin, TX
    Also worth noting that our lift gate seemed to inherit the height setting from the FWD -- that is, I'm not sure you can set the FWD to open fully and not have the lift gate also try to open fully.
  16. hahler2
    hahler2 Member
    South Dakota
    Thank you for the info mal!
  17. muleferg
    muleferg Supporting Member
    North Wilkesboro, NC
    My driver side will not open fully if I go in to far that the manual closer is in the middle of the door. Open's when it at the front.
  18. mal_tsla
    mal_tsla Member
    Austin, TX
    Convert to jackshaft opener. No floating motor, no chain, no center track.
    It's worth it if you have a model X!
  19. Aljohn
    Aljohn Member
    Georgia
    you may wish to check a prior thread.... it has all the measurements for the Model X right after its launch.
    teslamotorsclub.com/tmc/threads/model-x-dimensions.60228/#post-1311432
