Will MX fit in my garage?
Discussion in 'Model X' started by ohmman, Sep 8, 2015.
Tags:
  1. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    Smart move. My reservation is after yours, and I agree. Very happy to be a latecomer in this respect.
  2. Jerico
    Jerico Member
    Spain
    I don't know if this has been pointed out in this thread or the others linked here but just in case. Didn't Elon said that those doors wouldn't go higher than any hatchback or tailgate of other SUV's? I googled how high was the Q7 with the tailgate open since it was the one Elon was comparing the X with and I just got a rough number from a Q7 owner, 220cm. That's less than 87" so I think it will be 85". If someone has the exact figure or can get it, thanks for sharing.
  3. ohmman
    North Bay, CA
    Elon did say something like this. However, as much as I respect Elon, I've learned to ignore a lot of these comments.
  4. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    I'm sort of wondering if this is dependent on air suspension.
  5. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
  6. Jeva
    Jeva BKINTME
    Cincinnati OH
    You know nothing John Snow
    (sorry I had to say this...GOT reference).
    I would think the air suspension would give a few inches leeway.
  7. ohmman
    North Bay, CA
    Now that deliveries are trickling in, this might be a good place to add real-life measurements.
    Cosmacelf has included this photo: a980c453fb8bbdf3f1624981ec259bd6.jpg
    Measurements to the lowest point of the garage door is 7'6", with garage ceiling at 9'.
  8. KJD
    KJD Supporting Member
    SLC, UT
  9. ohmman
    North Bay, CA
    #29 ohmman, Jan 2, 2016
    Roamer posted this video in another thread. I'm asking for more details on obstruction height, and clearance width on the sides of the doors (looks just as tight as my garage!)
  10. DDG!
    DDG! Member
    Spokane, WA
    Thanks for the garage video.
    What happens when the garage door is closed?
    Do the door sensors detect the overhead tracks for the garage door?
  11. ohmman
    North Bay, CA
    Note: In Roamer's video, the right door took approximately 7 seconds to open. The more heavily obstructed left door took 15 seconds to open.
  12. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
  13. Roamer
    Roamer Member
    Mesa, Arizona, United States
    My left Falcon door is a little more obstruction sensitive. We plan to get it in for therapy. Given the choice I prefer more sensitive to less sensitive. In the video my helper did a hold the button down sensor override when the door stopped opening.
    I can't get you measurements right now. We are not at home. Brought the car home from delivery and grabbed a quick video in the garage then loaded it up and hit the road. By the end of delivery day we had 500 miles on the car. The next day anothe 100 plus.
    The P85D in the video was actually parked closer than normal and had the mirrors out. The FWD opened on that side with no problem at all.
  14. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Just got to check out a Signature Model X in person today and measured to the top of the Falcon Wing Door. I measured 90" to the top-most point, which is midway in the door. Just measured our garage door from the floor to the lowest point - 89". Might work, though I imagine it'll stop with some room, so maybe 3" short of its normal opening height. We'll have to see it in the garage first to say for sure.
    Also, opened normally where the sunroof portion is opened all the way to 90 degrees vertical, the rest of the door sticks out 18" from the side of the car.
  15. ohmman
    North Bay, CA
    Firstly, thank you! Second, do you know which setting was selected in the suspension during your measurement? I'd like to update the wiki with your data.
    There's over 3" of travel in the air ride. It's possible in your garage, where your obstruction is at 89", you could set the car to always lower to "very low" and get yourself a bit of extra space.
    18" is not bad at all. What was your reference point on that measurement? (e.g. side panel of the driver door).
  16. EarlyAdopter
    Redmond, WA
    Drat, I meant to check the suspension setting but forgot. It was pretty chaotic there with a good 30+ people all over that car :) Hopefully someone else took note of the setting. For now, I have to assume it was the default, which I understand to be "low." I didn't see anyone playing with the suspension height the whole time I was there.
    18" out was indeed from the side panel of the driver door.
    Also, I'd note that the rails of my garage door are at the standard 88" high, but because of the way the falcon wing doors slope down that shouldn't be the limiting factor. The intersection point will be a good foot or more in from the rails. Because the garage door sits an inch up in the track on its rollers, that gives me (and hopefully others) a tiny bit of extra room.
  17. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    Kittylitter's Model X was in "Low" which apparently is the "Normal" setting for the Model X (of course now I don't know which of the many people I met there you are... can you jog my memory?)
  18. FarmerDave
    FarmerDave Supporting Member
    Central PA
    Garage Parking Help
    For those making an initial installation of a Model X in their garage, I offer the following suggestion for parking in exactly the same spot every time:
    The dual laser garage pointer about $25, sold here Amazon.com: MAXSA Innovations 37312 Park Right Garage Laser Park, Dual Lasers: Automotive
    I've used it for over six years and it has worked without fail. Just position the vehicle(s), point the laser(s) at a spot on the car (I use a seam on the dash), and pull the car in to that point each time. I've no vested interest here, just passing on a tip for folks putting a big expensive car in the garage.
  19. goneskiian
    goneskiian Active Member
    Bellevue WA
    Wow! Great idea! Much better than the tennis ball hanging from a string we've been using! Haha! ;-)
  20. westerndh
    westerndh Member
    I have wall cabinets 40" above the floor in my Garage and I want to check if the front of Model X will fit under the cabinets. Can anyone advise the min / max height of Model X. I think a height measurement 15" in from the front of the car would be fine ie aligned to the front edge of the tire?
