If you think you might get a 2nd EV in the future, then consider putting in a subpanel. You can connect a Gen 3 to the subpanel and be able at add a 2nd one later (load sharing is built in). WIth one Wall Charger you can install a 120V 20A outlet as well, and with two chargers you can still install a 120V outlet and just limit the load sharing capacity.
Since you have a Gen 1, you would connect the Gen 1 to the subpanel. Later, if you add another connector, you will have a handy panel to support whatever you may want.
