Will new battery fuse allow for faster Super Charging?
Discussion in 'Model S: Battery & Charging' started by P85_DA, Jul 21, 2015.
  1. P85_DA
    P85_DA Supporting Member
    Curious to know as couldn't find anywhere ..but will the new fuse hardware allow for faster super charging ?
  2. spottyq
    spottyq Member
    Belgium
    #2 spottyq, Jul 21, 2015
    What limits charging is the power that the cells can accept, not the fuse. (A battery cell can accept less power input than what it is capable of getting out; whereas the fuse does not care which way the current flows.)
    A fun calculation : taking the 'old' fuse limit into account and a low pack voltage for the 85kWh battery yields a maximum power through the fuse at 350V * 1300A = 455kW. Clearly, that's not the bottleneck for charging !
    [Edit :] As randompersonx said, the 1300A rating is burst, not continuous, so my calculation is moot.
    Anyhow, I do not believe the 'old' fuse is what limits supercharging at 120kW, but I do not have any evidence to back this up.
  3. P85_DA
    Thanks for the explanation I was just looking for another excuse to justify ludicrous upgrade :)
  4. randompersonx
    randompersonx Member
    Orlando, FL
    I don't recall off the top of my head what the continuous rating is for the standard fuse, but 1300A is the burst rating, not continuous.
    The continuous rating is much lower.
  5. spottyq
    spottyq Member
    Belgium
    You are right.
  6. ThosEM
    ThosEM Space Weatherman
    Annapolis, MD
    Charging is limited by the parasitic energy dissipated by resistance internal to the cells, which tends to heat them and cause chemical modifications such as plating of the electrodes, if I understand it right. So dissipation in an external switch should not be relevant to the warming of the cells' innards, whereas active cooling of the pack is very relevant. A superconducting battery could presumably be charged at an arbitrary rate.
  7. scottm
    scottm Legacy account
    Canada
    One limit of supercharging is the number of AC inverters hooked up in parallel inside the big box behind the fence.
    It takes a dozen of those to generate 120kW DC.
