The receptacle on the left is a NEMA 6-30. Tesla doesn't make a UMC adapter for it, but evseadapters does:
I can't tell what the receptacle on the right is.
Yes, EVSEAdapters makes really good stuff. They make one for the TT-30 too, if you want one of those. You will notice the prices for theirs are always higher than the ones from Tesla, and that's because they are buying official ones from Tesla as the starting part and then taking them apart to change the plug type to something that Tesla doesn't offer. But they do preserve the temperature sensor in the plug and the chip that signals the proper amount of amps for that plug type, so you are getting a really good one that acts just like an OEM real one.
I suggest doing a bit more than crossing your fingers. You should take the time (or have someone do it) to remove the coverplate and check that the outlet is in good repair. Of couse kill the circuit breaker before doing so. Make sure the wires are at least 10ga. Look for signs of heating, and make sure the wires are firmly crimped into the outlet. If anything looks janky at all, replace the outlet with a good quality one.Thank you all for your help. This is a great way to pass along wonderful information! I have ordered the 6-30 adapter and will cross my fingers everything works out well for charging.
That sounds like a great plan. Is it safe to use this 6-30 plug for the Tesla as the main charging station? Or should I plan on getting a Tesla recommended plug completed in the garage in the future?
One more minor thing you might look into. If that is a few feet up above the floor, you might not want all the weight of the plug and the electronics box and more cord hanging from that outlet unsupported. So some type of bracket to hold the electronics box might be a good idea. And that doesn't have to be something Tesla-specific. Many people do this with one of those bicycle water bottle holders screwed into the wall. But if you want to search, I think there are people selling 3D printed brackets shaped specifically for this.Any more tips would be much appreciated! Thank you!
Tesla is still a month away!
I just turned off and opened up the outlets and they look great.
I notice the top receptacle is on a normal 15 amp breaker. Could I use this with regular electronics (internet modem) knowing the amperage won’t go too high or should I not use it because of the kind of outlet it is?
Thank you for the help!
