Like a weight distributing hitch for goosenecks, Safety Hitch distributes trailer tongue weight to two truck axles. That’s the biggest towing problem for newer 1/2 ton trucks, they have low axle ratio options, enough horsepower and torque and brakes for larger trailers, but have semi-floating rear axles that are not made for constant loads. With Automated Safety Hitch, the trailer tongue weight is spread out to the truck axle and the Safety Hitch axle.
<snip>
Gooseneck ball placement is adjustable for and aft or up and down. 3 point receiver hitch is Class V for 16k trailer by itself, when using with Automated Safety Hitch, it’s tested for a 30k trailer with 6300 lb tongue weight. Look at allot of flatbed semi trailers, they will have 9 ft between the trailer axles and they don’t steer. Does take a little more room to back up with the extra 9 ft. but you get use to it quickly.
