Will the Gemini Rim’s increase the range of a Model 3?
Reeler
Decade of Pure EV Driving
Oct 14, 2015
1,766
1,318
Denver, CO
Looks like the Model Y got a range increase to coincide with these 19” rims becoming standard. The stock 18” ones that were on the Model 3 are gone as an option. Does that mean that the Gemini would be the most efficient even with their larger diameter?
Good luck getting a set. I ordered back in the beginning of December and have had two failed attempts to pick them up. Next try is Feb 11th
The 19" Model Y Gemini rims looks the same with the wheel covers as the 19" Model 3 Gemini rims, but according to the Model Y owners' manual they're quite a bit bigger. The Model Y versions are 9.5" wide with a 45mm offset while the Model 3 versions are 8.5" wide with a 35mm offset.
I think it is likely that the 19" Model 3 Gemini wheels are very slightly more efficient than the 18" Aero rims. On the China website, it shows the Performance model, which comes with the Gemini wheels in China, as having 5 miles more range than the long range dual motor with the 18" Aeros. It sounds like you wouldn't lose range with the 19" Gemini wheels and you might gain a little.
