Note: This feature currently requires accessing the site using the built-in Safari browser.
What sort of information are you able to obtain from a license plate? Go ahead, I'm waiting...Not that it's cool to do what this driver did but posting a picture of the license plate is over the top. I can only imagine what you do when your neighbor's TV is too loud.
Are you still waiting?What sort of information are you able to obtain from a license plate? Go ahead, I'm waiting...
Every time I see that, I 100% plug them in and make sure they're accruing idle fees
I cant be sure, but when my S90D in my garage (locked) and later when I don’t have my key with me, I can initiate charging by pressing the button on the HPWC connector to have the port pop open, insert the plug and begin charging. SpC cord should work the same way.For those unfamiliar:
If the car is locked, plugs can be neither inserted nor removed.
The car becomes celibate, so to speak.
yes. Or be idle, depending on the state of the battery and the charge set point.Wait, can you actually plug in a locked S? Would it start charging?
It's been this way since the early days.Well I sit corrected. You can indeed plug in, but not unplug.
I feel like this behavior has changed sometime over the years, but I could be remembering incorrectly.
I can most certainly open the charge port and plug in the cable on my fully locked and celibate model S.
