Will the lack of temperature regulation hurt the battery if it's not being driven?
Discussion in 'Model S: Battery & Charging' started by kjl, May 13, 2014.
  1. kjl
    kjl Member
    SF Bay Area
    My car is in a shop getting repaired (I hit another car at like 10 mph, which was apparently enough to puncture the radiator - apparently there's a radiator - who knew...), and it's taking them longer to repair it than originally thought. At the end it'll end up being about 2 weeks, and it's apparently completely off (my phone can't see it - the app says mobile connectivity is off), and I assume that with the radiator broken there's no battery temperature regulation.
    Do I have to worry about the battery degrading over these two weeks? I dropped it off at about 80% charge probably, and it's been sitting, I assume, with no heating or cooling.
  2. strider
    strider Active Member
    NE Oklahoma
    In the Bay Area? No worries at all, even with the heat wave this week. Active cooling doesn't start until the battery reaches 104F and it has a lot of thermal mass (ie, takes a lot of energy to heat it up and it's not hot 24 hours/day). So if you could ask them to leave it parked inside or in the shade you should not worry at all. And even if it's in the sun the battery won't go over 104 before the temps will start falling again overnight.
  3. kjl
    kjl Member
    SF Bay Area
    Thanks - that puts my mind at ease. Do you think I need to worry about it getting too cold at night? I mean, just for curiosity - the next week's going to be pretty warm even at night it looks like...
  4. Rainbow
    Rainbow Member
    Speculation & opinion: I would suspect that they would disconnect the traction battery and the 12 V accessory battery for safety and to protect the batteries. If the batteries are disconnected it should eliminate most of the parasitic drain. A disconnected battery should be able to last several months without any harm. In my opinion if they don't disconnect the batteries and if there is any damage from not being disconnected for service, then they should replace any of the affected batteries without any additional cost to you.
    If it's not been charged or drained, it I doubt it would need any thermal regulation for the expected temperatures in your region.
  5. strider
    NE Oklahoma
    No need to worry about cold damaging the batteries until it's below zero.
  6. tezco
    tezco Sig P85
    Colorado
    Yes, storage life is better at cooler temps (although output is better when warmer). Check out table three at Battery University.
  7. djp
    djp Model 3 Performance
    Toronto, Canada
    Active cooling starts at 104F on the Roadster and 140F on the Model S. There's no chance of hitting that in storage, unless you're leaving the car in a black metal box in the sun! Active cooling can kick in on a track or during Supercharging, but that's about it.
  8. William13
    William13 Active Member
    South Bend
    The battery is not damaged by cold storage until long term below -20F.
    The battery has more damage ongoing at high temperature while highly charged. IE there is more damage if 90% charged at 100F than 60% charged. Similarly there is more damage ongoing at 100F than 90F while 90% charged. Unfortunately we have no statistics to define how much is occurring or if there are real inflection points like the 104F active cooling might suggest. I suspect the actual storage issue would be higher than the 104F as that is likely set to prevents the temp from hitting 110F or some such.
