Or maybe a 120 KWh, motor-per-wheel version?
Per Wheel?
0 to the next dimension in negative 4 seconds lol.
It goes so fast you ripped a new time continuum and went negative/traveled back in time.
Per Wheel?
Yes. Four motors + zero differentials --> unprecedented torque control and effieiency.
Per Wheel?
The weight transfer is to the rear, so the front wheels are more likely to spin. On my car the torque on the front motor reaches its maximum first and begins to decrease as the rear torque continues to increase.(The front wheels are less likely to be spinning under hard acceleration due to weight transfer, so there's less benefit there.)
Yeah, I agree with that. The rear torque peaks at 600 Nm while the front is only 300 Nm. The gains wouldn't be huge, though. It's only the difference between static and sliding friction for the tires on road, similar to what a locking differential would provide.Oops. I expressed that poorly. You're right, the front wheels will spin at a lower torque level.
What I was trying to say is that having individual control over the rear wheels is more useful because you can get more acceleration out of optimizing them, precisely because they have more grip.
These guys seem to agree with you.Pretty much - with the added benefit of being able to torque vector for better steering/handling and stability control.
Not a large difference, no, but with the P100DL already putting state of the art road tires on the friction limit all the way to 60, little gains are all that's possible until better tires come along, unless you put on semi-slicks...
Not wit hthe current 18650 cell. The next larger battery will use the new 21700 that are in the 3. They have 33% more capacity per cell, making a P133 possible with the same amount of cells as current (though that would be a larger pack), but we'll probably see familiar capacity packs that weigh less first. The increased cell size means we'll probably also see a dramatic refresh soon, rather than the small cosmetics we've had so far. The frame will need to fit the new battery and I doubt it'll be retrofit capable.
Eventually solid state batteries will be here with all the advantages they can bring (both safer and higher energy density), but the prototypes are only in labs now. Unless Tesla has been working in secret on something and is way ahead of the publicly announced progress, we probably won't see solid state cells until the 2020s, possibly not until mid-decade. There are a lot of steps between the lab and full production and they aren't out of the lab yet.
It is possible Tesla might see a 20% improvement in energy density when they start putting 2170s in the S/X line, which could mean a jump to 120 KWh for the top of the line. I expect a major refresh sometime early next year, though it may be coming sooner with Tesla's announcement of the end of free supercharging at the end of this month instead of the end of this year as they had initially announced. I definitely expect the interior of the S and probably X to get a facelift. I expect some of the nicer features from the 3 to be ported over while at the same time being nicer than the current interior. I hope they keep the two screen layout, I don't like the center screen only of the 3.
Elon has said there are no plans to go beyond 100 KWh for a while, but that's in Elon time, which is very flexible. The GigaFactory is ramping up car battery production now and they need to stay ahead of the Model 3 ramp up curve, but there will come a point where 2170s for the cars will have enough production to support the Model S and X too and that's when Tesla will likely switch over to the new cells. The Model 3 will be a priority and they will need to make sure Model 3 production will never be disrupted for a shortage of batteries and there are enough to cover the S/X lines before they switch over. They will likely switch the large or small pack first, then switch the other after a while like they did with the 2nd gen 18650s and I believe they will be doing with the small packs (getting 100 KWh pack modules for a new 85 or 90 pack as the entry model) soon.
Once the GF is producing enough to support all Tesla production, Panasonic can shut down their Asian factories to switch over to 2170s, or supply other car makers from Asia depending on Tesla's needs.
I strongly doubt there will be a quad motor version of the Model S/X. The P100D is kind of a gimme on top of the 100D. Change out the back motor for the RWD car motor, change the fuse on the pack, and do some firmware changes and the car is a super car. The P100D is a vastly profitable car for Tesla. It costs them almost nil over the 100D to make and they charge a hefty premium.
For the standard cars, there is little gain from quad motors. The dual motor design for the S/X added range as well as performance, so it was the logical way to go, but quad motors won't gain much of anything for the regular sedans and they won't add enough to the Performance cars to make it worthwhile. If Tesla ever comes out with a quad motor, it will be in the next gen Roadster, but even there I don't think it will happen.
Tesla started up market because that was where the money was for their first two generations of cars, but Tesla's long term plan is to become the next Toyota not the next Porsche. If they happen to have some high performance cars that come out of other projects, they will make them, but they aren't going to set out to make super cars. The P100D will not be the king of the drag strip for long, there are electric super cars coming that will eat its lunch, but I don't think Tesla will really care. Bugatti or Lamborghini can sell a handful of cars to a year to some super wealthy people, but Tesla will be putting millions of cars into the driveways of people all around the world.
If a super car company goes all electric, that is a novelty. Most of those cars will be driven less than 1000 miles a year. Put 1 million electric cars on the road every year with an average of 12000+ miles a year and you will literally be changing society. Even if autonomous Ubers don't happen, if the middle class goes electric, that will be a major shift.
So a quad motor car is going off in the wrong direction for Tesla. If and when the next gen Roadster happens, maybe, but don't hold your breath. Elon has gone back and forth on the Roadster a number of times, though with the current referral program maybe it will happen. Who knows.
Just acknowledging that just because there's an anticipated average 7% gain at the cell level per year (which may be along one of several different axes: cost per KWh, energy density, etc...) that doesn't mean that we'll necessarily see a 7% larger pack each year. For several reasons:
- It's an average, so there will be variance...
- Testing takes time
- Some changes my require other engineering changes (for instance, the new silicon anode cells may have had an impact on how the batteries need to be charged)
- There are production/marketing/support factors that influence how often to release major changes
Thus, it's more reasonable to expect that the changes we see in a new pack release have aggregated some of the changes in cell design up to that point.
Doesn't Tesla have an 18650 purchase agreement with Panasonic and their Osaka plant? Is there an expiration on this agreement? Is that publicly reported? I would expect this would determine when the S/X change to 2170 would occur.
