Will these wheels fit a 2022 Model 3 Performance?
Looking for a winter wheel/tire option for my 2022 M3P. There seem to be more tire options with the 19” wheels so I’ve been looking at these:
Would they likely fit or would I need a spacer of some sort?
Thanks in advance.
They will fit, but will look tucked into the wells. The offset is about the same as the performance wheels while they are 9" wide. It may not matter to you on a winter set, but I had the V1 19" OEM sport wheels (which were +40 offset) and didn't like the look. 35mm Offset might not be too bad, but thought I'd throw it out there
Adding on to this thread...
I have a 2023 M3P and am looking to replace the stock 20" Uberturbine wheels with the following, which are 1.5" wider (9" stock vs. 10.5") and have a slightly different offset. I'm looking to get a flush fit. Any idea of whether these will fit or if I'll need a spacer?
I'm also planning to lower the car on coilovers about 1" to 1.5".
Rohana Rfx13 Mid Wheel 20x10.5 5x4.5 (5x114.3) Brushed Bronze 38MM
