Will V3 superchargers accelerate battery degradation?
Discussion in 'Model 3' started by Nuclear Fusion, Mar 8, 2019.
  1. Nuclear Fusion
    Your mum
    What say you?
  2. M109Rider
    M109Rider Member
    Kitchener, Ontario
    No.
  3. Zoomit
    Zoomit Active Member
    SoCal
    Of course—Li-ion batteries degrade with heat.
    BUT I do not expect any degradation due to high current charging will be enough to be noticeable over the cycle-based degradation. Basically, it’ll be lost in the noise.
    • Informative x 2
  4. timk225
    timk225 Active Member
    Pittsburgh
    I don't think Tesla would allow it if they thought it would significantly harm the batteries. Having said that, I don't think it'd be good to use these v3 superchargers on a regular basis.
    I also think this whole 1000 mile per hour thing is largely a gimmick. I've seen the early charts of how much faster it'll charge from 8% to 90%, but if the charge taper begins at only 18%, then that is not the same as tapering at 50% or some other much higher percentage. They say "It'll charge 1000 mph". They don't say " It'll charge 1000 mph, but only for a few minutes".
    This is a (lack of) truth in advertising. They only tell one side of the story. The part the non-technical masses can understand.
  5. golfpilot
    golfpilot Member
    Modesto, CA
    Will these be slightly more expensive then the V2 chargers, to start at least? Will they be pay only?
  6. golfpilot
    golfpilot Member
    Modesto, CA
    I rarely charge past 20-30% as I only use it to get home to .11-.14 cent energy. It will now take me more time to get off and on the freeway than it will do get the energy needed to get home. "To get home" is the intended use for these unless you are travelling 400+ miles in one day. But how often do we really do that?
  7. Troy
    Troy Active Member
    #7 Troy, Mar 8, 2019
    No, because Model 3 was designed from the beginning to support Supercharger V3. See my message (second paragraph) from 2017 here. That's why the oldest Model 3 supports Supercharger V3 but the newest Model S/X don't.
  8. brur
    brur Member
    Prescott AZ
    Does that mean you maintain your battery at 20 to 30%? 30% out in the morning and 30% home in the evening?
  9. Pseudo Expert
    Pseudo Expert New Member
    New Jersey
    I'm pretty sure he means that when you need a Supercharger it's when you are on a long trip. He charges it just enough to get him home where he can pay a cheaper rate.
  10. MentalNomad
    MentalNomad Member
    The model 3 comes with an extensive industrial-grade liquid cooling system for the battery. Battery temperature is closely monitored, including during the charging cycle, and this is part of why the charge rate declines during the course of a charge... When the battery is heating up faster than the cooling system can handle it, it backs off on the charging power.
    The new higher charge rates won't have much of a negative impact on battery life because the system is limiting charge whenever it's creating more heat than the system can handle.
  11. animorph
    animorph Active Member
    Scottsdale, AZ
    The chart of power versus state of charge looks like V3 tapers the power just like V2, and starts tapering earlier when running at it's highest powers. That might run the battery closer to its limits for longer, but it still respects the same limits as V2. I'd expect very little difference in battery stress compared to V2.
  12. jsmay311
    jsmay311 Member
    Chicago suburbs
    Will it hurt at all? Probably some amount.
    Will it hurt significantly? Hopefully/probably not.
    Still, what I find most interesting is that it appears Tesla has changed the V2 taper curve when the Supercharger is not current-limited.
    So this tells me Tesla (and/or Panasonic) engineers made an earlier determination back in 2017 of how many amps (or what C-rate) were acceptable at a given %SOC without causing excessive battery degradation, and they used that to formulate the taper curve, and now they have changed that earlier decision to allow more amps.
    Without insight into what drove this decision process, we can’t know what the motivations or drawbacks are. Maybe monitoring real-time battery pack health in the existing Model 3 fleet has allowed them to empirically determine that they were unnecessarily conservative in their previous decision and could safely go higher without any drawbacks.
    But it also seems plausible (or, IMO, likely) that they made a deliberate decision to accept a little more battery degradation (particularly in frequent Supercharging vehicles) order to reduce charging times, decrease SC congestion, etc.
  13. Knightshade
    Knightshade Active Member
    NC
    Even the folks who were doing 100% of their charging via supercharger, to 100% battery, multiple times a day, were getting hundreds of thousands of miles out of their older-tech 18650 S/X batteries... so I wouldn't be too concerned about occasional supercharging on the 3 battery.
  14. insaneoctane
    insaneoctane Active Member
    Southern California
    I think the general consensus here is correct. Tesla has been very conservative in their supercharger rates vs damage as proven by the data. Tesla battery degradation vs everything else is almost non existent. I suspect that the data allowed them to increase the rates with minimal impact. I would guess that it is not a zero impact, but relatively small and evaluated to be worth the convenience.
  15. powaking
    powaking Member
    Massachusetts
    Pretty sure once everyone's free supercharging offering expires there will be even more availability at the stations.
  16. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    With the new Superchargers, Tesla will have much finer control over charging.
    Combine this the all the battery degration knowledge they have obtained over the years, and I suspect they wlll be able to allow faster charging, but still retain long battery life.
    With Supercharging, we are talking about direct current to the DC batteries. No invertor required. This is the most pure way to charge the Li batteries.
    Imaging that Tesla will roll these out to areas where the most congestion is being experienced. Later it will be implemented on the long distance route where travelers will enjoy the quicker, en-route charging speeds.
  17. robski
    robski Member
    Bay Area
  18. StellarRat
    StellarRat Active Member
    Pacific
    Do you not think that Tesla has already thought of that? I'm sure they know how to protect the batteries in their cars.
  19. robski
    robski Member
    Bay Area
    I'm 1000% they've thought of it but they need to tell the public. We can only go on their last official word.
  20. run-the-joules
    run-the-joules Active Member
    SF Bay
    That said, aren't a bunch of customer cars now permanently throttled?
