M maserati Member Feb 3, 2016 19 11 london Nov 28, 2017 #1 Nov 28, 2017 #1 Any idea on this excessive wind noise from passenger window only noticed it around 70mph and above ??
Penfold Member Nov 10, 2017 370 225 Surrey Nov 28, 2017 #2 Nov 28, 2017 #2 maserati said: Any idea on this excessive wind noise from passenger window only noticed it around 70mph and above ?? Click to expand... Speed limit is 70 so should be ok sticking under this sorry couldn’t resist but I have no actual real helpful information Reactions: Terry_B58
M4guy Member Nov 13, 2017 124 53 Liverpool Nov 28, 2017 #3 Nov 28, 2017 #3 I’d try making sure the seal is located properly and the window is all the way up (often you can reset the stop location of fully up and down on electric windows) You can also try some gummi pflege https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG
DJP31 Active Member Aug 30, 2015 1,805 1,232 UK Nov 28, 2017 #4 Nov 28, 2017 #4 M4guy said: I’d try making sure the seal is located properly and the window is all the way up (often you can reset the stop location of fully up and down on electric windows) You can also try some gummi pflege https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG Click to expand... ^ This and the quarterlight seal in particular I think are known to sometimes be a bit iffy.
WannabeOwner Well-Known Member Nov 2, 2015 9,170 5,337 Suffolk, UK Nov 28, 2017 #5 Nov 28, 2017 #5 Didn't know such a thing existed, thanks chaps. Link to Amazon UK in case helpful: https://www.amazon.co.uk/Nextzett-91480615-Rubber-Stick-White/dp/B004B8GTQG EDIT: The Geek in me was sufficiently interested in the similarly of the two URLs, so found that this also works: https://www.amazon.co.uk/dp/B004B8GTQG Need to, now, try to remember that all I need is the DP path and Ref No in future when I see a DotCom Amazon URL
A Asterix187 Member Oct 7, 2017 733 683 England Nov 29, 2017 #6 Nov 29, 2017 #6 I have noticed this same thing. Its a bit of as hame we have to buy a £7.50 tub of stuff to fix an issue on an £70k+ car though.
DJP31 Active Member Aug 30, 2015 1,805 1,232 UK Nov 29, 2017 #7 Nov 29, 2017 #7 Asterix187 said: I have noticed this same thing. Its a bit of as hame we have to buy a £7.50 tub of stuff to fix an issue on an £70k+ car though. Click to expand... Some would argue it's a £20k car with a £20k iPad and £30k battery
