Wind Noise
Discussion in 'Model S' started by Beau24, May 1, 2015.
Tags:
  1. Beau24
    Beau24 Member
    Boston, MA
    Does the wind noise emitting from front pillars or small triangle corner glass annoy anyone else? I've had it addressed a few times and it does seem quieter but eventually, the noise comes back. Is it just poor seals Tesla is using, not enough insulation some where or something else? My 2006 CLS 500 is far quieter after all these years than my Tesla. I don't think it's unreasonable to ask for a quiet ride cruising at 65-75 mph.
  2. mknox
    mknox Well-Known Member
    Toronto, ON
    I don't have any air leaks, but agree I do notice the wind rushing around the A-pillar more so than I have on most of my past cars. It might have something to do with the frameless door window glass. My last car had full frame windows and triple door seals.
  3. cbin97
    cbin97 Member
    Orange County
    I agree it bugs pretty bad. I had an Audi before my S and it had a closed sealed door and you could feel/hear the the door close and seal in the car, very quiet.
  4. preilly44
    preilly44 Member
    Bethesda, MD, United States
    It annoys me as well. I've had it looked at twice and each time it slowly comes back. My $35k VW E-Golf is much quieter at all speeds.
  5. Beau24
    Beau24 Member
    Boston, MA
    I spent some time in LA this past weekend with my buddy who picked up his 2015 Model S a few weeks ago -- same, if not worse, wind noise. It must be the frameless design. However, I'm pretty sure my Mercedes is also frameless and it's pretty damn quiet. First world problem, for sure...but for a $100,000 car, I have a hard time getting over it.
  6. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I think frameless has lots to do with it. But mine has been very quiet up to 95mph. I have no complaints so far.
  7. Tdriver
    Tdriver Member
    Palm Desert, CA
    Make sure you keep the rubber and mating metal surface clear of sand and grit. Turbulence around the mirror adds to the problem.
    To check the seal add a coating of light oil to the rubber, drive for a short time and see if there is a continuous sign of oil on the mating surface.
  8. ljwobker
    ljwobker Geek.
    Raleigh, NC
    I think I remember reading that there was a service bulletin for the door seals and the wind noise... maybe someone else knows the details (or maybe I'm totally making that up...)
  9. preilly44
    preilly44 Member
    They claim to have done the service bulletin on mine (which I had to tell them about) but the wind noise came back after a couple weeks. For me, the wind noise is coming from the little triangle window only on the drivers side.
  10. jsimon77
    jsimon77 Member
    Los Angeles, Ca
    Is what you are referring to a slight high pitched whistling sound? I've just started to notice this in my new P85D?
  11. Tuan
    Tuan Member
    Fresno, CA
    Sounds like I have the same problem with my 85D. It seems to come from the 2 small triangular windows in the front, but I'm not positive. I made an appointment with Tesla mid May for a diagnosis.
  12. jerry33
    Texas
    I did have some wind noise with my S85 early on, but an adjustment of the triangular windows fixed that. I thought it came back a few weeks after the fix, but it turned out to be tire noise (going over one of the few stretches of smooth roads caused the whistling to cease). Because the car is so quiet, tire noise appears louder than it actually is.
  13. nico1199
    nico1199 Member
    Orange County, CA
    i started to develop a wind noise only a week after delivery and came across this thread. initially i thought it was coming from the triangular window by the driver's mirror also, but it turns out that the driver's side window does not roll up all the way. i noticed it when i stepped out of the car and realized that the window was not fully up.
  14. STxTesla
    STxTesla Sig #1278
    Corpus Christi, Texas
    I have a Signature series Model S and it has had wind noise from the beginning. I always thought that it came from the glass panoramic roof not sealing properly when closed. It sounds like it is coming from the front right corner of the pano glass. If there is a TBB I would really like to see if Tesla Service can fix it...but I am not willing to pay for the repair or for a service call. This should be a Tesla expense for the quality of workmanship of the vehicle.
  15. mknox
    Toronto, ON
    You may well have a pano roof seal issue. Mine will give a "tea kettle" like whistle when it is very cold I assume because a rubber seal in the roof is shrinking a bit. The whistle goes away in warmer weather.
  16. Brass Guy
    Brass Guy Active Member
    Holbrook, MA
    That depends on whether you noticed before or after you closed the door. If you're new to the car you may not realize the windows drop 1/4 inch to clear the door trim when you open the door, and close again after you shut the door.
  17. clx
    clx Member
    SoCal
    How serious/loud is the wind noise? I have a S85 without pano roof, and I notice a subtle noise that sounded like wind noise when I'm driving fast on the freeway - it's not high pitched, and it sounds like the fan blowing on low speed. For someone who doesn't have this problem, can you comment on how quiet the car is supposed to be?
  18. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    I think there are two different issues being discussed here. One is the general noise of wind rushing around the car. Unfortunately I don't believe there is anything Tesla can do for this, as every Model S I've driven exhibits this. I've heard it in other cars as well, but in my Highlander the engine noise is louder and so masks the exterior wind noise. Then there is the high-pitched tea-kettle style whistle, which is likely a compromised seal. I had this issue early on and there was a TSB (service bulletin) to re-seal the front pano roof appliqué. I had the whistling fixed about a year ago, so don't know what else Tesla has done since then.
  19. Tampaukfan
    Tampaukfan Member
    Tampa, Fl
    My 85D has more noticeable wind noise than my Audi A7 does, I think its due to the pitch of the windshield.
  20. Andyw2100
    Andyw2100 Well-Known Member
    Ithaca, NY
    There was. I started a thread about it when I learned there was a TSB:
    Service Bulletin for Wind Noise Issue on P85D
    I finally had my car serviced for that TSB, and it turned out my car already had the TSB parts applied, so they added some insulation or something, even though the tech stated he could not hear the wind-noise, which was of some concern to me. I don't know if he never took the car up to highway speed, or if he just couldn't hear the obvious wind-noise. In any case, what they did solved that problem, but now that it is solved, I can hear a lesser wind noise problem coming from further back in the car. I couldn't have heard that one while the first, louder problem existed.
    I wrote to my service advisor about this, and other questions I had about my recent service, but have not yet heard back. I guess it is time to follow up.
