kgb
DIY wind noise fix
Ok, here it is!
(I feel like such a showman... I am drumming up all this hype)
Here are is the equipment you'll need for the fix:
(1) A pair of scissors.
(2) 3/8 inch rubber foam weatherseal. Can it be some other weatherseal, maybe, but I chose this because of it had what I felt was the appropriate amount of sponginess and when cut, the remaining pieces maintain that property.
Here is a reminder of the gap's appearance.
Flip up the edge of the soft top convertible. Make note of where the rubber from the soft top was pressing on the door's rubber seal.
Tease the rubber seal from the A-pillar. In some places, the rubber will feel like it is glued to the pillar (It might be). Nonetheless, it is a pliable glue. You will need to gain access to the space behind the rubber seal. Only do this to the area where you are experiencing air leakage (near where the rubber seal meets the soft top).
You'll need about an inch of weatherseal.
3/8" is a little too wide. I cut it in half lengthwise.
The fact that it is self adhesive made it a little easier to work with. You can play with the placement and it stays there. You want to place the weatherseal between the rubber seal and the A-pillar.
This is what it looked like once it was in place and with the soft top snapped back down. See how the rubber seal is bulging out ever so slightly?
This is the picture with the door shut. The gap is now pin hole sized.
Makes you wonder why someone else (especially TM) hadn't come up with this earlier.
Ok, here it is!
